History DeDion axles on hot rods
Discussion in 'The Hokey Ass Message Board' started by Ned Ludd, May 27, 2009.
  1. Tire Changer
    Tire Changer
    from Wisconsin
    Yep. Gary Bettenhausen had one in a USAC spring car. Black 99. He also moved the fuel to side pods from the tail and it had an on board starter and could start going from a dead stop without a push truck. Freaked out the USAC community at the time! The one jealous car owner, at a race in Salem Indiana filed a protest claiming the car had illeagal areo-dynamics because the tops on the side fuel pods had a very minor incline front front to back. The De Dion suspension was also removed due to stability issues. But it was certainly some of the first innovations to that sport in many, many years!
  2. John Stauffer
    John Stauffer
  3. John Stauffer
    John Stauffer
    I once had a Clark Motor Home, maybe a 1969(?) that had a 225 slant six Dodge engine and it had a de Dion rear axle, but I don't know who made these axles. Anyone know of plans to built one's own de Dion rear for something under 400 HP ? I'm thinking of twin cantilever leaf springs (nostalgia) like John Cobbs Naiper Lion speed record racer, circa 1928.
  4. BillyShope
    BillyShope
    Don't know whether this has been mentioned, but one significant problem I've seen in the execution of a DeDion or IRS is the failure to recognize the positional shift of the constant percent antisquat lines. The result is terrible squat on acceleration. With the DeDion or IRS, the lines p*** through the tire centerline rather than through the tire patch. A similar problem arises when the drivetrain package from a front wheel drive is installed in the rear of a car. The instant center for the front wheel drive car is situated to minimize dive on braking. So, considerable work is needed to change its position for decent acceleration at***ude.
    Ned Ludd likes this.
  5. falcongeorge
    falcongeorge
    from BC
    Just sprayed coffee outta my nose!!:p:p I gotta remember that one, like I could ever forget it!!
  6. Rusty O'Toole
    Rusty O'Toole
    Most DeDions have telescoping axle shafts but the Rover used a telescoping dead axle. Reason, the axle shafts will bind under acceleration.
  7. dan griffin
    dan griffin
    In the early 50s Allards cleaned a lot clocks and they all had De Dion rear ends.
    dio
  8. Ned Ludd
    Ned Ludd
    The P6 went to a lot of trouble to avoid using CV joints! It had fixed-length, Hooke-jointed drive shafts, and thus required the axle itself to be variable in width. The sliding joint devised to achieve that also enables the "longitudinal Watts linkages" location, because it allows a bit of angular difference between the two parts. In all it's not an inelegant solution, as it uses complexity committed to for one reason to address at least one other reason, but it isn't the definitive DeDion.
    There is at least one well-known website which pooh-poohs the DeDion axle because of the compexity of the Rover system, as if that complexity were essential to the DeDion principle as such. It isn't.
    Most sensible would be to use CV joints in the way which has become standard on virtually every FWD car out there: one joint on each drive shaft, usually the inner, has a telescoping facility, either by the ball grooves of one element being formed straight rather than curved ("plunge" joints) or the inner joint sliding on a spline off the differential.
  9. Rusty O'Toole
    Rusty O'Toole
    Allard flailing arm front suspension
    For those who are not familiar... Allard suspension made of a Ford axle sawn in half
    And the same in action
    [​IMG][​IMG]
  10. falcongeorge
    falcongeorge
    from BC
    I wish my dad were still alive, he would have been rolling on the floor if he'd heard that! and yes, Allards won a lot of races, but it was in spite of the front suspension, not because of it. Great photos, especially this one...
  11. dan griffin
    dan griffin
    Does the term man handle apply?
    falcongeorge likes this.
  12. falcongeorge
    falcongeorge
    from BC
    Looking at that photo, I would say "HELL YES!":D
  13. gnichols
    gnichols
    from Tampa, FL
    RE Allards winning a lot of races... I suspect it was because of his American approach - put a huge *** engine it! Gary
  14. Mart
    Mart
    De dion rears and hot rods don't really go together. It's more a sports car setup. Ok, you may find one or two isolated examples but they are not mainstream hot rod fare. Personally I don't think they have "the look" of a hot rod.
    Mart.
