Projects defeat
Discussion in 'The Hokey Ass Message Board' started by TINGLER, Jul 15, 2006.
  1. TINGLER
    TINGLER
  2. Woogeroo
    Woogeroo
    from USA
    Look at it this way... you'll know lots about the Ford 8"... and in the future you can use that info. to win friends and influence people.
    :D
    -W
  3. Aaron51chevy
    Aaron51chevy
    Welcome to the 8" tugger club! I rebuilt my 8" last winter. Your going to have to beat off your 8" pinion, ok ok enough jokes! I rebuilt mine also, it was used and free. I put new bearings in it etc. The key is getting the lash and the pinion crush correct. Mine sat for a while and was actually rusted so it wouldn't spin!!! But some cleaning and scraping and it works, no whine or anything. If you need any help I found some good sites about rebuilding I can forward to you.
  4. Crusty Nut
    Crusty Nut
    Defeat sucks, but I do like the smell of 90 wt in the morning. Sometimes I dab a little behind my ears.:D
    but seriously, I just did the same thing with a 9 inch. It howls just a little around highway speed. I am going to convince myself that it is a quickchange whine. At least for a while.
    I have rebuilt both an 8" and a 9". Get a motors manual with all the specs and a dial indicator and it isn't that bad, just lots of readjusting everything so all the clearences are happy at the same time.
  5. Gator
    Gator
    Ahh, just look at it as a temporary setback, plus like the guys say, you're learnding.
    Gotta pass on Ratster's deal today, something unexpected came up - a temporary setback.
  6. RodLand
    RodLand
    Do you have a Radio? Volume UP.:D
  7. oldtin
    oldtin
    Tingler, Make sure the pinion nut hasn't backed off, a loose pinion will make growl pretty good. If the pinion nut is good check the torque on the ring gear, and check the wear pattern on the teeth. Your an artistic person, grab some prussian blue oil paint and check the mesh between the ring and pinion. If the ring and pinion are tight and the teeth show an even central wear pattern you probably need some new bearings.
    Don't ask me how I know this but...........some ford diff. housings had a magnet in them to help collect wear/sedament. If said magnet gets knocked loose and makes contact with the moving internals it will cause a howl.
  8. LUX BLUE
    LUX BLUE
    Alliance Vendor
    from AUSTIN,TX
    you should be happy it ain't a 12 bolt. at least you get to work on the chunk on your workbench,instead of on your back,under the car...
  9. jusjunk
    jusjunk
    from Michigan
    Ive still got that 8 inch third member in the shed we talked about before. Sorry but i got real busy with my dad passing away and having to fix up and sell his house then me having a heart attack 1 month ago. I cant lift anything that heavy right now but its still here if you need it and its free . all you gotta do is pay the shipping from michigan.
    my kid can help me get it sent out to you if you still want it.
    Dave
