Definitive S-10 Frame Swap Vehicle List
Discussion in 'Off Topic Hot Rods & Customs' started by Abomination, Jun 25, 2008.
  1. Abomination
    Abomination
    You know, I'm almost sure you'd find something like that on one of the ******** 4x4 boards. You'd likely be better off going with a Blazer though, as they shorter wheelbase will likely better match the original Jeep frame.
    Then again, if an S-10 can be swapped onto a K5 frame, you may be better trying that, lending (at least externally) to it's Jeepy-ness.
    Here's a link with lots of pics of how this guy did this:
    http://forums.s-series.org/viewtopic.php?t=47959&postdays=0&postorder=asc&start=0
    And a pic:
    ~Jason
  2. mad torquer
    mad torquer
    For my 50 ford convertible, the wheelbase of a longbed s10 was 114 inches, the same as the '50. I didn't like the s-10 setup in the back; so I used the front stub and made rear rails and used '67 chevy truck-arms. Very easy and fits nice.
  3. Abomination
    Abomination
    Thanks for the pic, mad torquer! 5150 Merc, there's an illustration of how to get around that funky rear. :D
    ~Jason
  4. bigtumtum
    bigtumtum
    Nice!! :D
  5. 5150merc
    5150merc
    that is cool.i was planing on just using the front susp off the s10 and grafting it to my frame like madtorquer did.but isnt the width from hub to hub narrower on the ford then the merc?
  6. C4 Metal Werks
    C4 Metal Werks
    There was one on Ebay this Summer. It looked good.
  7. Scott Danforth
    Scott Danforth
    Just a quick post from an FNG that may be appropriate.
    I have two AD trucks going together, one on an S-10 frame inspired by this posting http://www.jalopyjournal.com/forum/showthread.php?t=8491
    The other with a custom front cross member using the stock 1948 frame. The cross member uses GM Metric / S-10 A-arms and spindles however at the wider track width.
    Since there are way too many photos to list, here are some links:
    The 1948 5-window with a BBO planned on going into it - http://rides.webshots.com/album/560482736JOxVQx
    My cross member for 1947 - 1955 Chev and GMC trucks - http://good-times.webshots.com/album/561711357EzPphT
    and my 1953 Frankentruck - http://good-times.webshots.com/album/562699262CfcAqj
    Originally I picked up a '97 S-10 for the '48, however after researching the S-10 kits and not wanting to screw with adapters for the front end, different axles for the rear, I decided to take what I know, and design the cross member.
    Then I came across a '53 cab and front clip from Colorado for a good price and decided to put Frankentruck together. Fortune landed me a ***mins Diesel for motivation. Another running S-10 for $200 was procured for the Tilt column, wiring harness, transmission, wheels and front suspension components with the engine and rear sold and a pile of s**** turned in, Franken truck may be together for under $3k total. I plan on running wheels with the proper offset to eliminate the need for wheel spacers
    Now on to one of the roadblocks I have - I need to find a R&P for the S-10 ch***is
  8. smooth50
    smooth50
    from MASS
    Nice work on that crossmember!
    What are you soaking all your parts in for rust removal?
  9. Abomination
    Abomination
    ...vinegar?
    ~Jason
  10. Abomination
    Abomination
    You sir, are in inspiration! I'm glad you joined us!
    How did you find us, anyway?
    ~Jason
  11. Scott Danforth
    Scott Danforth
    1 part muriatic acid, 20 parts water. Pressure wash the bajesus out of it, repeat. Works best in warmer weather only taking 2 days. in temps down to 20, I used a stock tank heater to keep the mix from freezing.
    I then used metal prep and POR15
  12. Scott Danforth
    Scott Danforth
    Google as well as a few fellow stovebolters.
  13. Abomination
    Abomination
    Really? Great!
    I started this thread for just that reason - to help folks out there that wanted to do this. My goal was to have it come up on Google searches and word-of-mouth to reach the m***es. I'm glad I did. :)
    Hey - are there any stovebolters out there that have put 6-bangers in the S-10 frame? We're DYING for some pics over here! Send 'em our way, will ya?
    ~Jason
  14. Abomination
    Abomination
    You should totally snap more pics and post your formula as a tech thread!
    ~Jason
  15. bigtumtum
    bigtumtum
    damm that is cool... i wish you would post the DWG or DXF files for it that would be great...
  16. bigtumtum
    bigtumtum
    its funny if you typ 3100 s10 swap in google you see on the 2nd place this forum thread.. :D
  17. Scott Danforth
    Scott Danforth
    and if you type in 3100 ifs crossmember in google, you get my threads at the stovebolt.
    Google is a wonderful thing.
    Jason, the post is vefinative S-10 frame swap vehicle list. Has anyone actually compiled a list?
  18. bigtumtum
    bigtumtum
    when are these pages going to be edited... this post is great i realy loving it but if i want to read somepthing back i dont like the 40pages i have to read back...
  19. Abomination
    Abomination
    Have you tried the "search this thread" search, in the red bar towards the top of the page?
    ~Jason
  20. colts hotrod crazy
    colts hotrod crazy
    from Apex NC
  21. C4 Metal Werks
    C4 Metal Werks
  22. Abomination
    Abomination
    That is one low International...
    I'll bet if you stop it, then back up a few feet, you'll have collected a couple of hundred dollars in change!
    ~Jason
  23. Scott Danforth
    Scott Danforth
    The lowest you can get the cab and front clip for an AD chevy on an S-10 without a transmission tunnel is to mount the cab 3.5-4" off the frame. below that, you will need to put in a driveshaft tunnel. My cab is at 3.5, and I have to clearance the floor with a BFH metalworking tool in a small spot.
    2" drop spindles will help as well.
  24. Abomination
    Abomination
    Keep us posted on your rack & pinion findings, Scott:
    http://www.jalopyjournal.com/forum/showthread.php?t=317918
    ~Jason
  25. Ingo#147
    Ingo#147
    from Germany
    Yes. Here in Germany 4 Years Ago. Start with my 46 Ford Coupe from Chile. Rotten Floor and Frame. We use a S10 Single Cab Long Bed. Shorten the Wheelbase and Channel the Bodie 4" over the Frame.
    Shot with DMC-FX8 at 2007-08-23
    Chevy 350 Bored 030 with some Stuff and a T10 4Speed.
    Next Step.
    After a Lot Of Hard Work Back on The Street.
    Since Mai 08.
    Shot with DMC-FX8 at 2008-06-24
    #Ingo
  26. Abomination
    Abomination
    Very nice!
    Glad to see more Germans on the HAMB - welcome, my Bavarian friend! :D
    ~Jason
  27. thirty7slammed
    thirty7slammed
    from earth
    colts hotrod crazy,
    If you really wanna get low, you gotta cut the floor. here's a couple pic's of my template's.
    Later,
    Billy
  28. colts hotrod crazy
    colts hotrod crazy
    from Apex NC
    i was hoping that i wouldn't have to cut the floor. can you lower the motor any. i have the motor mounts for the v8 swap i was thinking that i could flip sides and it would lower the engine some.
  29. thirty7slammed
    thirty7slammed
    from earth
    Don't really know what mount's your using......but you gotta make sure you got clearance for your exhaust to upper control arm, and oil pan to crossmember.
  30. colts hotrod crazy
    colts hotrod crazy
    from Apex NC
    good point. i was gonna try it and see but i think you may be right its gonna be really tight. my mounts are the summit mounts i think.
