Definitive S-10 Frame Swap Vehicle List
Discussion in 'Off Topic Hot Rods & Customs' started by Abomination, Jun 25, 2008.
  1. Abomination
    Abomination
    This would take someone with a tape measure and a V8 in an S-10 frame to answer. That, or you can set your cab on the frame and go from there, on-the-fly...
    Ever been to http://www.s10v8.com/ ? They can help you out a LOT as well!
    ~Jason
  2. koolkemp
    koolkemp
    Ya I have the car and the S10 now...I built a 48 Chev 4 door turned Elcamino years ago but used a ranger ch***is (free!) then put a SBC in it. I am currently fixing the structural rot in the 47's body, and plan to strip the S10 in the next month or so, and hopefully have it on the ch***is before the end of the summer, dont worry I am and will be takin lotsa pics!!
    Heres the old 48 Chevy x 4 door on the ranger ch***is
    Heres the 47 Ford (project year round beater)
    And here is the $200 ch***is donor victim :D 97 longbox with lottsa miles and a cooked 4.3
    Cant wait to get started ripping apart the S10 gonna try and get it off the trailer tomorrow
  3. Undercover Customs
    Undercover Customs
    In researching the Stude I found that the cab and fenders are the same, just a 2 inch spacer on the big trucks between the fenders and body.. Sweet - I'm in.... Now looking for a donor suspect...
  4. Abomination
    Abomination
    Good hunting!
    ~Jason
  5. Lcdman
    Lcdman
    from Canada
    Thanks for the site link ... not to bad a price either. Right into the links collection :D
  6. Undercover Customs
    Undercover Customs
    I probably get my head blown off for this question, but here it goes...
    Has anyone done an early 90's Toyota truck frame? Adjustable torsion front end, Ford 5 lug bolt pattern....
    Don't shoot me....
  7. thirty7slammed
    thirty7slammed
    from earth
    Close but no cigar, still a very cool swap with torsion bar. Heres the link:
    http://www.jalopyjournal.com/forum/showthread.php?t=348374
  8. koolkemp
    koolkemp
    I have thought about it...but all the cheap parts trucks around here are cheap cause the frames rot really bad on them...much easier to find the S10!
  9. swizzlestick
    swizzlestick
    from Bedford VA
    when you guys say mount the cab 3 inches off the top of the frame on the AD chevy pickups is that measurment from frame to cab floor or from frame to the body mount braces?
  10. Abomination
    Abomination
    PLenty of parts... power steering...
    Hmmmmm... I do believe that the Toyota merits further scrutiny, especially in the area of the rear kickup of the frame - a major point of contention with folks that use the S-10 frame...
    ~Jason
  11. thirty7slammed
    thirty7slammed
    from earth
    Jason,
    I agree the toyota is probably another good choice, but as far as the kickup on the S10, although I did build a new rear clip, which is another alternative to stock I feel like I have ample bed room, not late model bed room, but plenty for my coolers and chairs. I'll be posting more pic's later but here's one:
    Later,
    Billy
  12. Edelbroke
    Edelbroke
    Here's a 36 Plymouth 2dr sedan on a 1997 Chevy S-10 reg cab short box frame. It only worked with the fenders on the car, the front part of the frame right behind the wheel comes out at about a 90 deg. if you wanna run fenderless the frame would have to be cut. Too big a job for the welder i was working with at that time, This was 3 years ago now, i wonder where this car is now. The S-10 frame I used had a custom 4-link and ran air ride when it was under the truck, I stuck VW Golf coil springs in.
  13. Edelbroke
    Edelbroke
    but why would you run fenderless with an S-10 suspnesion, I new there was a reason I did it that way
  14. Abomination
    Abomination
    Nice! :)
    ~Jason
  15. plodge55aqua
    plodge55aqua
    from Alberta
    On a S10 Pickup frame they are deep.. on a Blazer S10 Frame there about 3 inches shallower.. in the middle..
  16. roughidle
    roughidle
    from iowa
    I know a guy who put a 36/37 dodge on an s-10 frame without fenders, was making a rat rod out of it. Nobody had to tell him he was stupid, he could see it on our faces when opened the garage door. Needless to say he sold the whole dam car about two weeks later. lol
  17. Undercover Customs
    Undercover Customs
    Picking this up tomorrow - let the games begin.....
  18. Abomination
    Abomination
    Nice of you to join us! ;D
    ~Jason
  19. studeboy
    studeboy
    Well I guess its time I join this thread. I am working on a 49-53 Stude PU on a '96 S10 Blazer ch***is (4dr). The wheel base is approx 5" short of the Stude but that will be made up by using a 2 link moved back to fit the rear fenders. The frame is actually higher farther back than the axle centerline so the C notch might not have to be as deep.
    I'll take some pics of the body mounts when I take the cab back off to move the mounts back. (tacked them in a little to far forward.) The stock mounts are welded to 4x4x1/4 square tube. The tube was split into channel and trimmed to fit the ch***is. The actual rubber mounts are from the Blazer so replacements are easily available.
    Only have a couple old (been on 2yr hiatis after tornado tore house and barn down.) pics I took while step Dad and a buddy hold the fender in place. The only thing I can see as a possible drawback to this build is the track width is a bit narrow as you can see in the other pic. I have been considering taking a vertical section out of the front fenders to narrow them but I want to get all the sheetmetal hung before a final decision is made. Wheel spacers have also been considered but I don't want to add stress to the ball joints ,spindles, and wheel bearings. I could probably get away with an inch spacer before anything really gets to outta whack.
    Eric
  20. Err, with a full body car wouldn't you line it up so the wheels are centered in the wheel openings and move the motor mounts or cut the firewall as needed?
  21. Abomination
    Abomination
    Yep. ;)
    ~Jason
  22. Undercover Customs
    Undercover Customs
    Uh, been here - what you talking about.
    Doing a 46 Stude truck. I think I'll be fabbing a rear clip with a 4 bar. We'll see what comes along as this will be on the major budget.... I have enough parts for 2 trucks with parts left over... This one in the pic will get a redo on the existing frame and the parts left over will be the S10 driver...
  23. olyrailman
    olyrailman
    Jason;
    I am a little confused, from what I have read on this site I was brought to <style></style>believe that a S-10 was a good fit, it a '67-'72 F250 is better.
    Could you send me a few photos of a swap like that:
    My Email is (jimr1963@gmail.com.
    Thanks for the help...
    olyrailman
  24. BigChief
    BigChief
    Its extraordinarily off topic and I wouldn't have believed it with my own eyes but if you cut 23" out of the center and 15" off the rear of the frame a '78 VW Rabbit body (sans OEM firewall and floor) fits over the S10 ch***is like a glove. My son just picked up said project cheap and is going to try and finish it up this summer. YIKES!
    -Bigchief.
  25. Abomination
    Abomination
    Although I have no pics, the frame width is spot-on, and the length is almost prefect.
    Proof?
    The rear end out of one of those trucks BOLTS IN to your F2...
    ~Jason
  26. donnymopar
    donnymopar
    from MI
    I have only read about a 1/3 of the posts. But a fellow hamber Rusticdozer has a hot looking 53 Dodge on an s-10 frame. He has this posted in his hamb photo album. He is a terrific guy and convinced me to use an s-10 on my 54 dodge. We are building it now and I will try and get some pics up next week. [​IMG]
  27. Abomination
    Abomination
    Rock on!
    Any build pics are much appreciated, especially the details!
    It's pretty cool to see how different folks solve the same problems. :)
    ~Jason
  28. thirty7slammed
    thirty7slammed
    from earth
    donnymopar,
    You car ROCKS, how does it ride? Im doing the same thing to a 40 pickup. Im ***uming you have air ride, what are you using? This is a very in depth thread, plenty of good info, thanks for posting. Like Bo Didley said, you can't judge a book by looking at it's cover :D.
    Later,
    Billy
  29. ChromePlaterJosh
    ChromePlaterJosh
    I second that. From the dimensions I have came across, it appears it could work, but is anybody who has done it willing to share? Problems to expect?
    I went through the thread and could only find a mention of a Ranger frame used on a 48 Chevy, but not an S10 frame. I am considering an S10 ch***is for my 48 Fleetmaster 2 dr sedan.
  30. jeff0547
    jeff0547
    Off topic or not, I want to see pics!!!! :eek: :D
