Definitive S-10 Frame Swap Vehicle List
Discussion in 'Off Topic Hot Rods & Customs' started by Abomination, Jun 25, 2008.
  1. Scott Danforth
    Scott Danforth
    Unfortunately, only the Uni-steer R&P will work on the 2WD S-10 because it is way to @#$%#@$%^#$ narrow for anything other than an Appleton or Sweet rack from the racing world.
    I am keeping my eye out for a good deal on an Appleton or Sweet as I cant afford the Uni-Steer kit. I do have another idea that I am formulating for a rack based off an available rack with modifications for the 2WD S-10. Although I still need to get my trucks down to Florida (and find a place to work on them)
  2. 55 dude
    55 dude
    that looks great although the fenders on the 37' don't have depth of the 40's fenders. if you lookat my album pic's they were taken when the cab was set on the rails at random and still needed to be moved back 2".:(
  3. Scott Danforth
    Scott Danforth
    55 Dude, I couldnt find any '37 or 40 on your webshots page , a few 50's, a few 54's and a 66, however nothing older.
  4. kruzr
    kruzr
    55dude ,I didnt find any pics either of older trucks.
    Are you building a 37 or 38 ? in your last post you mentioned 37....maybe typo error?
    Like 37slammed says.38 is "close to" 40 style.
    Maybe you can post a pic of your project or at least front fender.
    You metioned 2"...you may have to "raise the fender (compensate for curve)"to move back two inches. that means the ride height will look two inches higher . so that means changing spindles. Depends where you want it to sit,,,,just goes on and on:D
    On page 6 theres an article about using explorer r&p...might be a little help to you.
    I dont know how to post the kink .:confused:
    Jerry
  5. Scott Danforth
    Scott Danforth
    Jerry,
    The explorer r&p still is too wide for a 2WD S-10. it fits on the 4x4, however there is no OEM automotive rack that I found that will work. However I have not ruled out the Chevette rack yet (as I cant find one). The Chevette (Opel Kadett) has one of the narrowest racks known. However bump steer may still be an issue, and the Chevette rack is a really light piece.
    Scott
  6. MrGasser
    MrGasser
    from DETROIT
    ...what about a Fiero rack?
  7. Scott Danforth
    Scott Danforth
    Still way to wide. The rack length from inner tie rod joint to inner tie rod joint needs to be about 16" - 18" max on a 2WD S-10. for reference, the Dakota rack and Explorer racks are about 26" If memory serves me right, the Chevette rack is just under 20".
    The S-10 tie rods come to the center link and are only 3-4" apart on the inner tie-rod joint. This was done for bump-steer reasons on the S-10 by the factory.
  8. dwjj
    dwjj
    Just starting '50 Pickup. Mine has a flatbed/stakeside bed. So wheelbase isn't so much of an issue.
    Question is-I can get a 4door Blazer with 107" wheelbase cheap. Would I be crazy?
    Is a Blazer frame that bad? Is it mostly a matter of stretching it a bit, and cutting off extra mounts? Or is there something else that's bad about using them?
  9. Scott Danforth
    Scott Danforth
    The blazer wheelbase is too short and you would end up stretching it a minimum of 9 inches. If its a 4x4, the frame you will have other issues.
    However, follow the link in my signature if you want a solution without all the work and you can use the Blazer for a donor.
  10. dwjj
    dwjj
    I don't have rear fenders to have to center wheels within, so my thinking was I have a bit more leeway on wheelbase. I was wondering whether there were other obstacles.
    I'll check out your link. Lots to think about!
  11. Scott Danforth
    Scott Danforth
    The stock wheel base on an AD is 116", the 117.8" wheel base of a long bed standard cab S10 actually centers the rear axle within the wheel wells. The short bed S-10 frame can be used if you move the rear spring hangers 8" forward and modify the back of the frame. The Blazer frame has different frame rails and kickups that would have to be modified to fit properly.
  12. dwjj
    dwjj
    But mine is a flatbed. No rear bed, no fenders in back, so no centering within wheelwells. The stock flatbed with wood stakesides is kinda different, so was planning on using that. Since no rear fenders, there isn't centering in back. I know there's a limit with increasing overhang, and at some point it would either look funky or handle funky with any loading, but the rear should be able to move front & back some without a reference to center it.
    <input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
  13. LowKat
    LowKat
    The Blazer frame is an inch taller (6") than a PU at (5")
    don't know if that makes any difference to you.
  14. All Steel 30 Plymouth
    from Kentucky
    Hey man I am so glad to hear you not going the chevy route. I got nothing against any of the brand X cars but there seem to be very few all Mo Par street rods out there. I went to Street Rod Nationals in Louisville this year and only saw a few.
    AS30Plymo
  15. Fitty-Tree
    Fitty-Tree
    from Canada
    Im putting a 53 Chev 5 window on an s10 frame. Frame is a reg cab s10, long box.
    For the guys that have done this did you just run the stock drive shaft?
    My set up is a 327 chev small block roughly 375HP bolted to a 700 R4 trans out of a 91 IROC. the rear end is a blazer 4x4 rearend.
    Any help is appreciated.
    The stock drive shaft is a two piece by the way.
  16. joel torres
    joel torres
    hey i was thinking has anyone tried using a van ch***is they are straight rails in the back right? there a box truck at my job and i noticed the ch***is was straight it runs on diesel i wouldn't mind my next project a big hefty old truck on that ch***is what do you think ?
    to give you an idea
  17. Scott Danforth
    Scott Danforth
    Since the motor will need to move back a bit (4") , you need to shorten the driveshaft. With that stated, you could go with a 1-piece drive shaft
  18. Scott Danforth
    Scott Danforth
    For a Big-Bolt maybe. I know that P30 axle swaps are common.
  19. Fitty-Tree
    Fitty-Tree
    from Canada
    Awesome Scott!!!
    Thanks for getting back to me.
  20. outlawsteel
    outlawsteel
    well kinda used s-10 ch***is for 41 willys build used front half anyway but if had to do again i would just build frame from scratch
      265.7 KB
  21. Fitty-Tree
    Fitty-Tree
    from Canada
    Im looking for some pics of body mounts that you guys have made.
    Any one have any pictures or design templates they are willing to post up? How high off the frame to the bottom of the cab did you guys mount the cab? Solid mounts or rubber bushings between the cab and the mount?
  22. Scott Danforth
    Scott Danforth
    So would I, So would I.
  23. Scott Danforth
    Scott Danforth
    I am up 2.5" with steel and another 1" with universal iso-mounts. Mounts can be gotten from McMaster Carr for cheep. The steel is 2 x 3 1/8" wall tubing with a 1/2" plate on top. There is another 1/8" spacer on the inside as the isomounts needed 3/4" steel in between the halves.
    I will still have to make a small tunnel. I believe 5" above the frame is the shortest you can go without modifying the floor.
  24. joel torres
    joel torres
    scott i really like that body mount i am stuck on making the two rear corner mounts for my car i now have another idea to look at thanks
  25. plodge55aqua
    plodge55aqua
    from Alberta
    Heres a question.. What do you do with the front end width if its to narrow? wheel Spacers? if so what kind??
  26. joel torres
    joel torres
    is this what you used ?
    on page 1358
    <table cl***="PrsnttnDisplHTMLTbl" width="100%" cellpadding="0" cellspacing="7"><tbody><tr><td cl***="PresentationHd" colspan="6"><table cl***="PrsnttnHdrTbl" width="100%" cellpadding="0" cellspacing="0"><tbody><tr><td cl***="PrsnttnHdrNm">Neoprene Vibration-Damping Mounts</td></tr></tbody></table></td></tr><tr><td width="1%" valign="top">
    </td><td width="13%" valign="bottom"><table><tbody><tr><td align="center" valign="bottom">
    </td></tr><tr><td align="center">3</td></tr></tbody></table></td><td colspan="2" width="13%" valign="bottom"><table><tbody><tr><td align="center" valign="bottom">
    </td></tr><tr><td align="center">4</td></tr></tbody></table></td><td width="13%" valign="bottom"><table><tbody><tr><td align="center" valign="bottom">
    </td></tr><tr><td align="center">5</td></tr></tbody></table></td><td rowspan="2" width="60%" valign="top"> For oil and ozone resistance in vertical load applications, choose these neoprene mounts. They isolate vibration, shock, and noise and are easy to install under machines and equipment such as generators, HVAC equipment, electric motors, pumps, and blowers. Temperature range is 10° to 180° F. Color of neoprene is black.
    Styles 3 and 5 can be stacked for additional shock protection, unless noted. </td></tr><tr><td colspan="2" width="14%" valign="bottom">
    </td><td width="11%" valign="bottom">
    </td><td colspan="2" width="14%" valign="bottom">
    </td></tr><tr><td colspan="6" valign="top"><table cl***="PrdctTbl" cellpadding="0" cellspacing="0" cols="10"><tbody><tr><td cl***="TblHd">
    </td><td cl***="TblHd">Loads per Mount, lbs. </td><td cl***="TblHd">Deflect. @ Max. Load </td><td cl***="TblHd">Durometer </td><td cl***="TblHd">(A) </td><td cl***="TblHd">(B) </td><td cl***="TblHd">(C) </td><td cl***="TblHd">(D) </td><td cl***="TblHd">(E) </td><td style="border-color: rgb(255, 255, 255); border-width: 0px; padding-right: 3px;" cl***="TblHd" align="right">Each </td></tr><tr id="TR103" onmouseover="TrMouseOver(this);" onmouseout="TrMouseOut(this);"><td colspan="10" cl***="ColBanner">
    </td></tr><tr style="" id="TR104" onmouseover="TrMouseOver(this);" onmouseout="TrMouseOut(this);"><td cl***="TblData Wd" colspan="10">Neoprene </td></tr><tr style="" id="TR105" onmouseover="TrMouseOver(this);" onmouseout="TrMouseOut(this);"><td cl***="TblData">3 </td><td cl***="TblData">130</td><td cl***="TblData">0.175"</td><td cl***="TblData">40A</td><td cl***="TblData">1.12"</td><td cl***="TblData">0.12"</td><td cl***="TblData">0.81"</td><td cl***="TblData">1.75"</td><td cl***="TblData">0.63"</td><td style="border-right-width: 0px; width: 111px;" cl***="neCol"><table cl***="InnerTbl" width="100%" cellpadding="0" cellspacing="0"><tbody><tr><td cl***="InnerTblCell">64865K85</td><td cl***="InnerTblCell" align="right">$1.54</td></tr></tbody></table></td></tr><tr style="" id="TR106" onmouseover="TrMouseOver(this);" onmouseout="TrMouseOut(this);"><td cl***="TblData">3 </td><td cl***="TblData">200</td><td cl***="TblData">0.175"</td><td cl***="TblData">50A</td><td cl***="TblData">1.12"</td><td cl***="TblData">0.12"</td><td cl***="TblData">0.81"</td><td cl***="TblData">1.75"</td><td cl***="TblData">0.63"</td><td style="border-right-width: 0px; width: 111px;" cl***="TblDataCellWithInnerTbl"><table cl***="InnerTbl" width="100%" cellpadding="0" cellspacing="0"><tbody><tr><td cl***="InnerTblCell">64865K86</td><td cl***="InnerTblCell" align="right">1.54</td></tr></tbody></table></td></tr><tr style="" id="TR107" onmouseover="TrMouseOver(this);" onmouseout="TrMouseOut(this);"><td cl***="TblData">3 </td><td cl***="TblData">250</td><td cl***="TblData">0.175"</td><td cl***="TblData">60A</td><td cl***="TblData">1.12"</td><td cl***="TblData">0.12"</td><td cl***="TblData">0.81"</td><td cl***="TblData">1.75"</td><td cl***="TblData">0.63"</td><td style="border-right-width: 0px; width: 111px;" cl***="TblDataCellWithInnerTbl"><table cl***="InnerTbl" width="100%" cellpadding="0" cellspacing="0"><tbody><tr><td cl***="InnerTblCell">64865K87</td><td cl***="InnerTblCell" align="right">1.54</td></tr></tbody></table></td></tr><tr style="" id="TR108" onmouseover="TrMouseOver(this);" onmouseout="TrMouseOut(this);"><td cl***="TblData">3 </td><td cl***="TblData">400</td><td cl***="TblData">0.175"</td><td cl***="TblData">70A</td><td cl***="TblData">1.12"</td><td cl***="TblData">0.12"</td><td cl***="TblData">0.81"</td><td cl***="TblData">1.75"</td><td cl***="TblData">0.63"</td><td style="border-right-width: 0px; width: 111px;" cl***="TblDataCellWithInnerTbl"><table cl***="InnerTbl" width="100%" cellpadding="0" cellspacing="0"><tbody><tr><td cl***="InnerTblCell">64865K88</td><td cl***="InnerTblCell" align="right">1.54</td></tr></tbody></table></td></tr><tr style="" id="TR109" onmouseover="TrMouseOver(this);" onmouseout="TrMouseOut(this);"><td cl***="TblData">4 </td><td cl***="TblData">100</td><td cl***="TblData">0.26"</td><td cl***="TblData">40A</td><td cl***="TblData">1.06"</td><td cl***="TblData">0.47"</td><td cl***="TblData">1.78"</td><td cl***="TblData">3.00"</td><td cl***="TblData">0.62"</td><td style="border-right-width: 0px; width: 111px;" cl***="TblDataCellWithInnerTbl"><table cl***="InnerTbl" width="100%" cellpadding="0" cellspacing="0"><tbody><tr><td cl***="InnerTblCell">64865K201</td><td cl***="InnerTblCell" align="right">5.20</td></tr></tbody></table></td></tr><tr style="" id="TR110" onmouseover="TrMouseOver(this);" onmouseout="TrMouseOut(this);"><td cl***="TblData">4 </td><td cl***="TblData">150</td><td cl***="TblData">0.26"</td><td cl***="TblData">50A</td><td cl***="TblData">1.06"</td><td cl***="TblData">0.47"</td><td cl***="TblData">1.78"</td><td cl***="TblData">3.00"</td><td cl***="TblData">0.62"</td><td style="border-right-width: 0px; width: 111px;" cl***="TblDataCellWithInnerTbl"><table cl***="InnerTbl" width="100%" cellpadding="0" cellspacing="0"><tbody><tr><td cl***="InnerTblCell">64865K202</td><td cl***="InnerTblCell" align="right">5.20</td></tr></tbody></table></td></tr><tr style="" id="TR111" onmouseover="TrMouseOver(this);" onmouseout="TrMouseOut(this);"><td cl***="TblData">4 </td><td cl***="TblData">230</td><td cl***="TblData">0.26"</td><td cl***="TblData">60A</td><td cl***="TblData">1.06"</td><td cl***="TblData">0.47"</td><td cl***="TblData">1.78"</td><td cl***="TblData">3.00"</td><td cl***="TblData">0.62"</td><td style="border-right-width: 0px; width: 111px;" cl***="TblDataCellWithInnerTbl"><table cl***="InnerTbl" width="100%" cellpadding="0" cellspacing="0"><tbody><tr><td cl***="InnerTblCell">64865K203</td><td cl***="InnerTblCell" align="right">5.20</td></tr></tbody></table></td></tr><tr style="" id="TR112" onmouseover="TrMouseOver(this);" onmouseout="TrMouseOut(this);"><td cl***="TblData">4 </td><td cl***="TblData">300</td><td cl***="TblData">0.26"</td><td cl***="TblData">70A</td><td cl***="TblData">1.06"</td><td cl***="TblData">0.47"</td><td cl***="TblData">1.78"</td><td cl***="TblData">3.00"</td><td cl***="TblData">0.62"</td><td style="border-right-width: 0px; width: 111px;" cl***="TblDataCellWithInnerTbl"><table cl***="InnerTbl" width="100%" cellpadding="0" cellspacing="0"><tbody><tr><td cl***="InnerTblCell">64865K204</td><td cl***="InnerTblCell" align="right">5.20</td></tr></tbody></table></td></tr><tr id="TR113" onmouseover="TrMouseOver(this);" onmouseout="TrMouseOut(this);"><td cl***="TblData Wd" colspan="10">Neoprene with Steel Top Plate </td></tr><tr style="" id="TR114" onmouseover="TrMouseOver(this);" onmouseout="TrMouseOut(this);"><td cl***="TblData">5 </td><td cl***="TblData">75</td><td cl***="TblData">0.10"</td><td cl***="TblData">40A</td><td cl***="TblData">*</td><td cl***="TblData">*</td><td cl***="TblData">1.00"</td><td cl***="TblData">2.50"</td><td cl***="TblData">0.63"</td><td style="border-right-width: 0px; width: 111px;" cl***="TblDataCellWithInnerTbl"><table cl***="InnerTbl" width="100%" cellpadding="0" cellspacing="0"><tbody><tr><td cl***="InnerTblCell">64865K94</td><td cl***="InnerTblCell" align="right">5.14</td></tr></tbody></table></td></tr><tr style="" id="TR115" onmouseover="TrMouseOver(this);" onmouseout="TrMouseOut(this);"><td cl***="TblData">5 </td><td cl***="TblData">100</td><td cl***="TblData">0.10"</td><td cl***="TblData">50A</td><td cl***="TblData">*</td><td cl***="TblData">*</td><td cl***="TblData">1.00"</td><td cl***="TblData">2.50"</td><td cl***="TblData">0.63"</td><td style="border-right-width: 0px; width: 111px;" cl***="TblDataCellWithInnerTbl"><table cl***="InnerTbl" width="100%" cellpadding="0" cellspacing="0"><tbody><tr><td cl***="InnerTblCell">64865K95</td><td cl***="InnerTblCell" align="right">5.14</td></tr></tbody></table></td></tr><tr style="" id="TR116" onmouseover="TrMouseOver(this);" onmouseout="TrMouseOut(this);"><td cl***="TblData">5 </td><td cl***="TblData">150</td><td cl***="TblData">0.10"</td><td cl***="TblData">60A</td><td cl***="TblData">*</td><td cl***="TblData">*</td><td cl***="TblData">1.00"</td><td cl***="TblData">2.50"</td><td cl***="TblData">0.63"</td><td style="border-right-width: 0px; width: 111px;" cl***="TblDataCellWithInnerTbl"><table cl***="InnerTbl" width="100%" cellpadding="0" cellspacing="0"><tbody><tr><td cl***="InnerTblCell">64865K96</td><td cl***="InnerTblCell" align="right">5.14</td></tr></tbody></table></td></tr><tr id="TR117" onmouseover="TrMouseOver(this);" onmouseout="TrMouseOut(this);"><td cl***="TblData">5 </td><td cl***="TblData">250</td><td cl***="TblData">0.10"</td><td cl***="TblData">70A</td><td cl***="TblData">*</td><td cl***="TblData">*</td><td cl***="TblData">1.00"</td><td cl***="TblData">2.50"</td><td cl***="TblData">0.63"</td><td style="border-right-width: 0px; width: 111px;" cl***="TblDataCellWithInnerTbl"><table cl***="InnerTbl" width="100%" cellpadding="0" cellspacing="0"><tbody><tr><td cl***="InnerTblCell">64865K97</td><td cl***="InnerTblCell" align="right">5.14</td></tr></tbody></table></td></tr><tr style="" id="TR118" onmouseover="TrMouseOver(this);" onmouseout="TrMouseOut(this);"><td cl***="TblData Wd" colspan="10">Neoprene with Steel Top and Bottom Plates </td></tr><tr style="" id="TR119" onmouseover="TrMouseOver(this);" onmouseout="TrMouseOut(this);"><td cl***="TblData">5 </td><td cl***="TblData">250</td><td cl***="TblData">0.21"</td><td cl***="TblData">40A</td><td cl***="TblData">*</td><td cl***="TblData">*</td><td cl***="TblData">1.25"</td><td cl***="TblData">2.75"</td><td cl***="TblData">0.63"</td><td style="border-right-width: 0px; width: 111px;" cl***="TblDataCellWithInnerTbl"><table cl***="InnerTbl" width="100%" cellpadding="0" cellspacing="0"><tbody><tr><td cl***="InnerTblCell">64865K81</td><td cl***="InnerTblCell" align="right">7.00</td></tr></tbody></table></td></tr><tr id="TR120" onmouseover="TrMouseOver(this);" onmouseout="TrMouseOut(this);"><td cl***="TblData">5 </td><td cl***="TblData">350</td><td cl***="TblData">0.21"</td><td cl***="TblData">50A</td><td cl***="TblData">*</td><td cl***="TblData">*</td><td cl***="TblData">1.25"</td><td cl***="TblData">2.75"</td><td cl***="TblData">0.63"</td><td style="border-right-width: 0px; width: 111px;" cl***="TblDataCellWithInnerTbl"><table cl***="InnerTbl" width="100%" cellpadding="0" cellspacing="0"><tbody><tr><td cl***="InnerTblCell">64865K82</td><td cl***="InnerTblCell" align="right">7.00</td></tr></tbody></table></td></tr><tr id="TR121" onmouseover="TrMouseOver(this);" onmouseout="TrMouseOut(this);"><td cl***="TblData">5 </td><td cl***="TblData">450</td><td cl***="TblData">0.21"</td><td cl***="TblData">60A</td><td cl***="TblData">*</td><td cl***="TblData">*</td><td cl***="TblData">1.25"</td><td cl***="TblData">2.75"</td><td cl***="TblData">0.63"</td><td style="border-right-width: 0px; width: 111px;" cl***="TblDataCellWithInnerTbl"><table cl***="InnerTbl" width="100%" cellpadding="0" cellspacing="0"><tbody><tr><td cl***="InnerTblCell">64865K83</td><td cl***="InnerTblCell" align="right">7.00</td></tr></tbody></table></td></tr><tr style="" id="TR122" onmouseover="TrMouseOver(this);" onmouseout="TrMouseOut(this);"><td cl***="TblData">5 </td><td cl***="TblData">600</td><td cl***="TblData">0.21"</td><td cl***="TblData">70A</td><td cl***="TblData">*</td><td cl***="TblData">*</td><td cl***="TblData">1.25"</td><td cl***="TblData">2.75"</td><td cl***="TblData">0.63"</td><td style="border-right-width: 0px; width: 111px;" cl***="TblDataCellWithInnerTbl"><table cl***="InnerTbl" width="100%" cellpadding="0" cellspacing="0"><tbody><tr><td cl***="InnerTblCell">64865K84</td><td cl***="InnerTblCell" align="right">7.00</td></tr></tbody></table></td></tr><tr style="" id="TR123" onmouseover="TrMouseOver(this);" onmouseout="TrMouseOut(this);"><td cl***="TblData">5 </td><td cl***="TblData">660</td><td cl***="TblData">0.20"</td><td cl***="TblData">40A</td><td cl***="TblData">1.27"</td><td cl***="TblData">0.31"</td><td cl***="TblData">1.46"</td><td cl***="TblData">4.06"</td><td cl***="TblData">0.63"</td><td style="border-right-width: 0px; width: 111px;" cl***="TblDataCellWithInnerTbl"><table cl***="InnerTbl" width="100%" cellpadding="0" cellspacing="0"><tbody><tr><td cl***="InnerTblCell">64865K89</td><td cl***="InnerTblCell" align="right">16.00</td></tr></tbody></table></td></tr><tr style="" id="TR124" onmouseover="TrMouseOver(this);" onmouseout="TrMouseOut(this);"><td cl***="TblData">5 </td><td cl***="TblData">1100</td><td cl***="TblData">0.20"</td><td cl***="TblData">50A</td><td cl***="TblData">1.27"</td><td cl***="TblData">0.31"</td><td cl***="TblData">1.46"</td><td cl***="TblData">4.06"</td><td cl***="TblData">0.63"</td><td style="border-right-width: 0px; width: 111px;" cl***="TblDataCellWithInnerTbl"><table cl***="InnerTbl" width="100%" cellpadding="0" cellspacing="0"><tbody><tr><td cl***="InnerTblCell">64865K91</td><td cl***="InnerTblCell" align="right">16.00</td></tr></tbody></table></td></tr><tr style="" id="TR125" onmouseover="TrMouseOver(this);" onmouseout="TrMouseOut(this);"><td cl***="TblData">5 </td><td cl***="TblData">1400</td><td cl***="TblData">0.20"</td><td cl***="TblData">60A</td><td cl***="TblData">1.27"</td><td cl***="TblData">0.31"</td><td cl***="TblData">1.46"</td><td cl***="TblData">4.06"</td><td cl***="TblData">0.63"</td><td style="border-right-width: 0px; width: 111px;" cl***="TblDataCellWithInnerTbl"><table cl***="InnerTbl" width="100%" cellpadding="0" cellspacing="0"><tbody><tr><td cl***="InnerTblCell">64865K92</td><td cl***="InnerTblCell" align="right">16.00</td></tr></tbody></table></td></tr><tr style="" id="TR126" onmouseover="TrMouseOver(this);" onmouseout="TrMouseOut(this);"><td cl***="TblData">5 </td><td cl***="TblData">1800</td><td cl***="TblData">0.20"</td><td cl***="TblData">70A</td><td cl***="TblData">1.27"</td><td cl***="TblData">0.31"</td><td cl***="TblData">1.46"</td><td cl***="TblData">4.06"</td><td cl***="TblData">0.63"</td><td style="border-right-width: 0px; width: 111px;" cl***="TblDataCellWithInnerTbl"><table cl***="InnerTbl" width="100%" cellpadding="0" cellspacing="0"><tbody><tr><td cl***="InnerTblCell">64865K93</td><td cl***="InnerTblCell" align="right">16.00</td></tr></tbody></table></td></tr><tr style="" id="TR127" onmouseover="TrMouseOver(this);" onmouseout="TrMouseOut(this);"><td cl***="TblData Wd" colspan="10">* Does not have a projection at the base of the mount. Base is covered by neoprene. Cannot be stacked.</td></tr></tbody></table></td></tr></tbody></table>
  27. Scott Danforth
    Scott Danforth
    http://www.mcmaster.com/#6309k4/=3mb34x
    These are close to the mounts that I used. The ones I actually used were from Tech Products (www.novibes.com)
    http://www.novibes.com/vibration/productinfo/universalmnts/index.asp
    http://www.novibes.com/vibration/productinfo/universalmnts/60031-35.asp
    The ones I used ere the 60032's, however the ones from McMaster are very similar. There are about a dozen companies that make these such as Tech Products, Lord, Sunnex, Soundown, vulkan, etc. I used rebound washers top and bottom (large washers like fender washers, however 2.5" OD x .135" thick.)
    Hope this helps.
  28. Fitty-Tree
    Fitty-Tree
    from Canada
    Thanks again Scott. Definitely gives me some ideas now.
    Anyone else have some insight on how hig the cab should be mounted for clearances.
    I am installing a 327 small block with a 700 R4 bolted to the back of it.
  29. rdstr31
    rdstr31
    from Ney, OH
    I did one a few years ago, but sold it before it was finished. I did the hard parts tho...
  30. Fitty-Tree
    Fitty-Tree
    from Canada
    Just ordered my kit from EZ-Ch***is Swaps.
