degree of front axle
Discussion in 'The Hokey Ass Message Board' started by 58belair, Dec 4, 2010.
  1. 58belair
    58belair
    im about to start setting up my front axle, its a 28 model a axle,
    at what degree do i set it at? i think ive heard of 7 degree down, but not sure...could u guys help me
    thanks
  2. EnglishBob
    EnglishBob
    5-7 negative (leaning back)
  3. captmullette
    captmullette
    got mine a 6.... we will see....
  4. 58belair
    58belair
    im also gunna have airbags on the front
  5. seventhirteen
    seventhirteen
    from dago, ca
    air bagged i-beam axle on a model A, how do you plan to do that?
    also 5-7degrees leaning back is standard
  6. DE SOTO
    DE SOTO
    Why would Anyone do this ?
  7. usmc50lx
    usmc50lx
    from St.Louis
    I've seen a few cars have it and some were very safe others not so much! the best one is the sedan in newstalgia wheels ad it has the bags located on gussets on the hairpins and attached to the frame. The axle is held by a panhardand typical hairpin radius rod set up still has shocks just has bags at the corners of the front crossmember and you really only notice it when yo go how the F!@$ did they do that! but it has straight axle looks and adjustabilty of air! to the OP run 5-7 degrees back and youl be fine!
  8. 58belair
    58belair
    why dont u think i can put airbags on the front...
    wishbones, panhard bar , bags and shocks
    am i missing something?/?/
  9. Gator
    Gator
    Yup.
  10. Blue One
    Blue One
    from Alberta
    Yes, you certainly are missing something :D
  11. metal man
    metal man
    Here we go again.Hold on a minute while I get some popcorn!
  12. 58belair
    58belair
    just asking dude,,,im new in to this
    ive tried looking it up but cant find anything that says it wouldnt work
    u tell me,
  13. metal man
    metal man
    No reason it won't work.It has been done successfully,but these guys are going to beat on you for not being "traditional".
  14. Thorkle Rod
    Thorkle Rod
    I agree it might work but it sure ain't gonna be very pretty, there is this saying that goes something like this
    "Just because you can doesn't mean you should"
  15. let's see some mock up pictures of what you are planning to do
  16. skipstitch
    skipstitch
    Please tell me it's gonna "lay frame".... That is the coolest thing EVER!
  17. metal man
    metal man
    Especially at speed in the dark with all the cool sparks!:rolleyes:
  18. 58belair
    58belair
    no pictures , yet
    but im thinking bags on the outside of the frame welded to the frame and axle with a panhard bar from the axle to the driver side frame rail. with shocks and wish bones........
  19. skipstitch
    skipstitch
    Bags on the OUTSIDE of the frame!?!
  20. 32ratsass
    32ratsass
    7 degrees has worked out very well for me. Re-think the bags! Trad' or not, it's going to be hard to get the "look" right.;)
  21. Blue One
    Blue One
    from Alberta
    That mental picture is enough to make you throw up in your mouth :eek:
  22. Ned Ludd
    Ned Ludd
    Wait a minute. What sort of build are you looking at? Fenders or no? Wheelbase? Hood?
    I think what a lot of the guys are picking up is, bags are ugly as hell. You'd rather want to hide them somehow. But it can definitely be done.
    How about this: make up some bell cranks. On either side of the car there's a bell crank with one arm pointing forwards and one arm pointing up. The forwards-pointing arm is on the outside of the rail, with a short link or shackle at its free end, attaching around where the stock spring perch is on the axle. The upwards-pointing arm is on the inside of the rail and activates a bag (perhaps with damper e.g. "Shockwave" - otherwise run dampers in the conventional position) lying on its side. The forwards and up arms are connected together by a short splined shaft running in a bearing in the frame rail: try a single-type front wheel bearing for a front-drive car. That's****uming there's enough room for the bags in the engine compartment. Keep the arms the same length. That way the required spring rate is the same as would be the case if the bags were directly on the axle, meaning you'll probably need the little cylindrical bags rather than the big sphericalish ones.
    Keep in mind there's more to bags than being able to adjust ride height. In fact I'd say there's something to be said for bags with no compressors or control systems at all, that you simply pump up from the filling station air line. Bags are rising-rate springs. Set up right, you'll be able to manipulate the gain in spring rate over travel so as to get a much cushier ride at ride height than any steel set-up, while ensuring enough rate gain over the next 2½-3" of bump for proper control.
    Finally make sure nothing touches the bags, especially if it is hot.
    But to answer your original question, it depends how much weight you've got on your front end and you want your steering to behave. The lighter the front end, the more caster you want. The more straight-line stability you want, the more caster you want. The more steering response you want, the less caster you want. The range is from zero if you want to slalom a COE truck, to 12° or more if you want to keep a FED on the straight and narrow. Most of the guys are saying 5-7°: that sounds about right.
  23. willowbilly3
    willowbilly3
    from Sturgis
    The Gas Monkeys had a bagged A sedan at WOW in Dallas a few years back. Fenderless with a 500 caddy. They had the bags fairly well concealed, not totally fugly. Not sure who built that car but they always said it was sold when they showed it. Don't want to get a***** storm going about those guys tho.
  24. nanos1932
    nanos1932
    I'm running 9 degrees. Handles fine.
  25. Roupe
    Roupe
    It may not be for everybody but I have a Cen-Pen Speed Shop air bag set up on the front of my '29 truck. It works good and most people don't even know its there.
    http://www.cenpen.com/traditionalair.htm
  26. tommy
    tommy
    Did you look at any other cars on this site? I'm just curious as to why you think anyone here would understand let alone have experience in what you want to do. The problem with trying to be different is there won't be much help or it wouldn't be different.
    The mental picture that I get from your ideas really looks ugly in my mind. The "RR" term comes to mind. Most of the guys here want to look at a car because it's beautiful and not because it is "outrageous"
  27. onedge
    onedge
    Unacceptable. Like Tommy says take a look around before you ask. Good luck.
  28. coopsdaddy
    coopsdaddy
    from oklahoma
  29. 58belair
    58belair
    thanks for the help guys,,,,i see everyone has there own opinion on it but i have traditional cars also but i want this one a little different.....and yes bags on the outside of the frame closer to the wheels give it better handling....
    i hope u feel better dude,,,next time throw up in a trash can, would hate to see someone choke on a nut,,,,,
  30. skipstitch
    skipstitch
    Well... technically, you can have**** with your sister... but it ain't right!
    Here's the deal, no BAGS and it handled like a slot car. I HATE to hear a compressor run, flip switches and watch gauges when I could be driving.... :) Not to mention the fact they are UGLY.... But, you could prove me wrong. I'm just some OLD (37) guy with a keyboard.
