Hot Rods Delco dizzy hold down for an 8BA timing cover/french block
Discussion in 'The Hokey Ass Message Board' started by johndee138, Oct 4, 2021.
  1. johndee138
    johndee138
    from Atlanta GA
    Im installing a french block motor with a delco dizzy. 8BA timing cover. I had a 1/4-20 bolt tapped into the shaft housing for a hold down. this isn't gonna do it.
    There is a flat on the head adjacent but no hole for any sort of attachment device.
    This metal the block is made of is pretty stout stuff. I have to tap some holes for the oil filter and I'm afraid I'll break a tap in the hole.
    Any suggestions on what I need?
  2. coilover
    coilover
    from Texas
    We never use the POS Loadamatic Ford distributor, even on a manure spreader engine. The external point adjustment Delco or electronic makes life much easier.
    8BA timing cover prepped
    Dist machined: IMG_4088.JPG
    Installed:
    williebill likes this.
  3. paleot
    paleot
    from louisiana
    I have a timing cover modified like the one in the picture,free if you want it.also have a aluminum cover off of a mercury I think? email tfain@centurytel.net
    johndee138 and Budget36 like this.
  4. 19Fordy
    19Fordy
    Nicely done. Problem solved.
