Delco generator rebuild questions.
Discussion in 'The Hokey Ass Message Board' started by flypa38, Nov 12, 2010.
  1. flypa38
    flypa38
    Hey fellas.....need to do a few things to get a couple generators working for my '56 Pontiac but need some advice.
    First I need to re-insulate my field coils. What should I use? I've heard fibergl*** tape or friction tape with a varnish over it. What type of tape and varnish do you guys recommend? Would plasti-dip be any good instead or would it melt?
    Secondly one of my spare armatures has no continuity between a few of the commutator blocks. One of the wires is loose where it meets the one section too. How do I fix this stuff?
    Finally, in case I do need to replace parts, can anyone recommend a manual or parts list that will list part numbers for my generator (such as which armature part# fits my 1100304 generator).
    I certainly have the option to get the generators rebuilt at a shop but would really like to learn this stuff myself.
    Thanks fellas!
    Johnny
  2. pauls fords
    pauls fords
    Really,,,,if you have never done this before my advise is to take this to a rebuilder and ask if you can watch,,,and ask this question,,,,What is a growler???? The rebuilder can get you all the parts you need....
  3. Mr48chev
    Try NAPA or a local generator rebuild shop for brushes and bushings for that unit.
    Napa doesn't show them online but they should still be in the paper catalog. The shop I buy a lot of my starter and alternator parts from up here can do the work or sell you the parts if you pull a blank there. PM me if you end up needing their contact info.
