Technical Delco remy 12v HELP
Discussion in 'The Hokey Ass Message Board' started by Thepartsbinguy1, Jan 24, 2020.
  1. Thepartsbinguy1
    Thepartsbinguy1
    from Space
    I have a Delco remy 12v starter generator for the $75 283 I finally found the box resistor for the points and the regulator that came with the generator. The Delco remy generator has two unmarked poles. The voltage regulator itself has three square posts sticking out of it. First post off regulator marked BAT second marked ARM third post marked FLD. A wire is connected to BAT post on the voltage regulator and that wire runs to another separate solenoid looking thing's B post. That solenoid looking thing also has three post sticking out of it first post marked H second marked B third post marked S is the second box a solenoid? Anyone know how to wire this starter generator up?
  2. Budget36
    Budget36
    I don't know how to hook it up, but I wasn't aware of a starter/generator combination for a SBC, could you post a pic of it? I'd just like to see what it looks like.
    Somewhere I have the wiring diagram for my '32 Dodge, it also had that same setup as well, but it'd be an act of congress to find the paperwork.
  3. Thepartsbinguy1
    Thepartsbinguy1
    from Space
    Until tonight I have no way of posting better pictures. But this is the regulator and what I think is the solenoid 17264333_779313908888291_4834587582623210629_n.jpg WIN_20200123_19_36_08_Pro.jpg WIN_20200118_19_24_42_Pro.jpg
  4. Budget36
    Budget36
    I see, that's just a generator (on the engine) and regulator, and what looks like a horn relay to my eyes. The white thing is a ballast resistor.
    I don't recall by memory how to wire it, but google search for say "1957 Chevrolet wiring/charging system".
  5. Thepartsbinguy1
    Thepartsbinguy1
    from Space
    Ok thank you! Now that I've found a base to start with can I just run fld wire from generator to fld on the regulator do the same with the arm wire and run a positive wire back to the battery off the regulators BAT post? Then ground generators frame to regulators frame? Don't need the horn relay or wire running to the ignition switch do I? I know how to polarize it once installed. I'm hoping that's it. Then can I power a volt gauge off the battery post on regulator to make sure it's correctly and safely charging right? 522513.jpg
  6. Thepartsbinguy1
    Thepartsbinguy1
    from Space
    22141334_892203010932713_4416454700583979354_n.jpg Once I go to test this can I run a wire off the BAT post from the voltage regulator to one post off this Amp meter and then run a wire off the second post from the Amp meter to the battery? The gauge works. Is it safe to run an Amp meter off the voltage regulators wire that sends the charge to the battery?
  7. Budget36
    Budget36
    It's safe, if done correctly, i/e wire size, routing, etc. Remember all the charging current is running through the ammeter.
    But before you go chasing gremlins, google up "how to motor up a generator" Whenever I've done it and the generator motors properly, I'm confident they'll charge as well.
  8. Thepartsbinguy1
    Thepartsbinguy1
    from Space
    I talked about this on the 283 thread. When I got it out of the barn it did not even try to motor. I s****ed the brushes and copper pads clean and it REALLY motors now. Just don't wanna wire anything up wrong because I've done that already in the past and it's not awesome. EDIT: Also once it's spun up touching the fld post slows it down very quickly so it must work a little bit at least
    Budget36 likes this.
