Technical delete
Discussion in 'Traditional Hot Rods' started by Pufff, May 30, 2017.
  1. Pufff
    Pufff
    done
  2. patmanta
    patmanta
    from Woburn, MA
    I see a lot of those go for twice that out my way.
    The big question is really is it a spool or does it have a locker in there?
    Does he have any gear sets to go with it?
    Pufff likes this.
  3. dirty old man
    dirty old man
    I'll say this: Neither of my hot rods could use this rear without extensive mods, but if I could get my hands on that setup, I would buy it tomorrow. If you don't buy it, please send me contact info by pm asap.
    grumpy32 and Pufff like this.
  4. Pewsplace
    Pewsplace
    The price is right if good on the inside. Would not work well in a street car without $$$.
    Pufff likes this.
  5. randydupree
    randydupree
    from archer fl
    it looks pretty good,and if you need him Jamie Frankland still does some work on thise old rears.
    Hes at Frankland Welding,in Balm Fl.
    Pufff likes this.
  6. 61cad
    61cad
    Price a new one.... Then... Cut that price in half.....
    You'll be pretty close to market price.
    Pufff likes this.
  7. X38
    X38
    Don't know about the QC, but I want to see the 19 foot pickle fork!
  8. Texas Webb
    Texas Webb
    Me too^^^^^.
    Pufff likes this.
  9. flamedabone
    flamedabone
    In my part of the world, we call that a Grand National rear end because of the bolt pattern, which is most likely 5 on 5 Chevvie. Chances are it has a spool, but there are many out there with differentials too. Lots of guys have put those under hot rods just the way it sits, but the best way is to open it up, check it out and install a differential if it doesn't already have one. (used diffs go for about $300 on ebay.) You can also go all the way and replace the axle tubes with p***enger car Ford style axle tubes, axles and brakes, but it is not mandatory.
    If he will let you open it up, you can remove some of the mystery, but if not, offer the guy 3 or 4 hundred. Take it home, open it up and go from there. Then, you have to find something cool to put it under.
    Good luck, -Abone.
    deadbeat and Pufff like this.
  10. dirty old man
    dirty old man
    OK Zane just let me know. Thanks
    Pufff likes this.
  11. flamedabone
    flamedabone
    I just noticed the extra fill hole in the right side bell. You MIGHT be able to shine a flashlight in there and tell if it has a spool or diff. If so, the small end of the spool will be about the size of a beer can, a differential will be much bigger. Either way, you need to drag it home and pet it.
    Good luck, -Abone.
    Pufff likes this.
  12. gpohl6
    gpohl6
    Got a nice serviceable 4.86 ring and pinion for an old Frankland or Winters to sell if you end up needing one. Private message if interested. Once I get some pictures, I will list it in the cl***ified section. It will be a little less than 1/2 of new price. I removed it to install a 4.12 R & P to couple with helical cut "small gears" for noise reduction for the street. Frankland Racing advertises rebuilds for $75 plus parts. Of course, the parts can add up quickly.
    Pufff likes this.
  13. X38
    X38
    Got it now. I thought is was a typo and you were talking about a 19" pickle fork for removing ball joints etc.:rolleyes:
  14. stillrunners
    stillrunners
    from dallas
    gee......and it's a disk brake set up.......should be loaded up by now.......we's got gears......spools can be set out on the curb.......just saying.......
    Pufff likes this.
  15. tubman
    tubman
    I was gonna say the change gears aren't a problem. I have a Frankland in my vintage dirt modified and have more gears than I need. Go to a circle rack swap meet sometime; they are everywhere, cheap. If you can't find what you want, Speedway has 'em for as little as $29.99 a set.
    Pufff likes this.
