Technical DELETE
Discussion in 'The Hokey Ass Message Board' started by KOTC, Feb 10, 2020.
  1. KOTC
    KOTC
    DELETE
  2. Mr48chev
    All I am finding on the GM herritage link is 6 inch rims with a 61 inch tread width. https://www.gmheritagecenter.com/do...formation-kits/Cadillac/1960_Cadillac_VVI.pdf
    If that doesn't work open this click on archives, click on vesicle information kits and then click on Cadillac.
    I'm thinking your 3=1/2 inches is close. Some years of Cads had wheel with the outer lip shaped a bit different to let the Cad hub cap hook up. I used to hate them things in the 70's when I was installing tires and doing brakes on them.
  3. What you got on there now?
    Start with something and see if you need more or less.
    If your in a pinch go 3.5 backspace because with a spacer you can get to 3”. If you order 3” you can’t get 3.5 out of it.
