For rear led brake & turn should need a 3 prong flasher , 3 connector is ground. any Led turn . I think I used a oem led flasher Gm was like $10 vs aftermaket $45 ish up. Check the glide light to see if mount/ housing is ground , or bubs have separate ground. A Good Ground is as important as a good solid power .
On turns if all 4 are Led a 3 prong flasher needed . I would disconnect wires , Use test leads One ground & One hot Test poles @ screws , verify working then proceed to connections. ohm meter to help test & diagnose Could be bad crimp , paint
Check power to brake switch for brakes. Power in & power out when brake pushed . If single filament bub , flasher break's Power to make blink in relationship with turn signal switch L & R
