Delivering the Kiwi goods.
Discussion in 'Off Topic Hot Rods & Customs' started by woodbox, Dec 8, 2024.
  1. Jiminy
    Jiminy
  2. woodbox
    woodbox
    Cool long roof FJ Holden from Australia. Very similar lines and design cues to the delivery.
  3. woodbox
    woodbox
    My son came to visit yesterday so we set to and located the axle center line on the jag ifs so we could position it correctly under the ch***is.
    I had been looking all over the interweb for the location of the theoretical axle center line of the jag ifs for a week. Turns out that the axle center line is even with the extreme lower rear edge of the flange of the cross member, dead centre of the forward 5/16" holes on the top of the rack mount brackets, 50mm behind the edge of the 1" spring center hole, the inside edge of the top arm rear mount bolt. Using the laser to project these points made this job a whole heap easier.
    Tomorrow the plan is to mark where to trim the cross member to fit the ch***is down into it.
    Stay tuned........
  4. 26 T Ford RPU
    26 T Ford RPU
    Happy New Year, Wade. See ya in a couple days.:cool: JW
    woodbox likes this.
  5. woodbox
    woodbox
    If you look close you can see the yellow marks on the cross member and the scribed marks on the ch***is. These represent the axle centers on each component. The dotted line is shows the outer edge of the spring pocket on the underside of the cross member.
    Please ignore the gas cut marks, I haven't cleaned up where I hacked off the unnecessary bits. All in good time.
  6. woodbox
    woodbox
    Choppy, choppy, grindey, grindey, weldey weldey, and .......repeat! That was the recipe for the day! IMG20250102141302.jpg
    The Jag cross member is an inverted channel section with a flat plate welded across the flanges on the lower edge. However, inside the channel is another narrow inverted channel plug welded to the outer.
    So when I chopped into the outer channel I needed to modify the inner channel to maintain the structural integrity of the overall beam.
    To do that I rewelded the top of the inner channel top back onto the sides in a lower position.
    On both sides.
    In order to clear the ch***is rails in the new recessed location a little m***age of the coil spring pocket was needed. IMG20250102141321.jpg
    On both sides.
  7. woodbox
    woodbox
    And then ease it back into position ready to make the main mounting plates and gussets tomorrow.
  8. 26 T Ford RPU
    26 T Ford RPU
    Very nice, is this the same process as the coupe? JW
  9. woodbox
    woodbox
    Yes JW, it is much the same as I have done on the 39. The plan is to get both ch***is to the same stage then do them both in parallel. Economies of scale stuff, rebuild both diffs and front ends, paint both ch***is etc, etc etc.
    26 T Ford RPU likes this.
  10. woodbox
    woodbox
    Crush tubes inserted into the front of both rails.
    I used a bimetal hole saw to cut through the top of the ch***is rail, through the brace for the bumper iron crush tubes that is in the middle of the rail, then a smaller hole for the fastening to p*** through.
    This shot shows the top hole cut with the hole saw and the smaller holes on the side of the rail for the bumper mounts.
    The crush tubes cut and ready to insert.
    In the hole ready to be welded.
  11. 26 T Ford RPU
    26 T Ford RPU
  12. woodbox
    woodbox
    Back on the job with the front cross member mounting.
    The adapter plates all ready to position and weld on to the jag beam.
    The slugs are to weld in under the adapter plates to later drill and tap for the rear fasteners.
    The slugs in position with a spigot through the lower skin of the beam later welded.
    The chamfered holes are for rosette welds to pick up the secondary center beam. The pair of holes on the right are above the slugs for the rear fasteners.
    All welding complete and rear holes drilled and tapped for fasteners.
    Up close on the left side.
    And the right.
    In the ch***is.
    Very happy with the results.
    Ready to sling all the hardware back on there and get one end on its wheels!
  13. 26 T Ford RPU
    26 T Ford RPU
    That's pretty slick.:cool: JW
    Uncle Ronn likes this.
  14. woodbox
    woodbox
    Now on to the rear end. Nothing much to see yet, but I did drag the diff outside to degrease and waterblast it so it is nice and clean to locate and fab some mounts.
  15. 26 T Ford RPU
    26 T Ford RPU
    Looking forward to the next stage. JW
  16. woodbox
    woodbox
    I had a 1 cubic meter plastic container that I previously used to dip parts in a mol***es solution, it is currently busy holding all manner of steel articles in my mum's shed but no mol***es! For this project I wanted the ability to dip whole major panels like hood, guards, doors etc, so....... IMG20250222161049.jpg
    .....a couple of days in and a bunch of retired pallets later, here we have it!
    Ready for a liner and ***ociated other details. The extra ribs on the floor are there to stop panels sitting on the bottom and not getting the benefit of the mol***es underneath.
    So the finished size is about 1650mm square x 600mm deep, so approximately 1.63 cubic meters which will need 163 litres of mol***es and the balance of water.
  17. woodbox
    woodbox
    IMG20250222163458.jpg IMG20250222163838.jpg With a banana for scale!
  18. 26 T Ford RPU
    26 T Ford RPU
    That's going to smell like a licorice factory..... mmmm :D JW
    firstinsteele and loudbang like this.
  19. woodbox
    woodbox
    Outside in position ready for the polythene inner tomorrow. The old pool is just to protect the inner. IMG20250224160513.jpg
    And I put it out to the world that I need a column, so look what arrived today!
  20. woodbox
    woodbox
    I prepped the hood by removing the brightwork and s****ing the liner.
    The top side had no paint to start with.
    10% mol***es 90% water mix.
    With the lid on to stop rain water over flowing it.
  21. woodbox
    woodbox
    A great day in the shop today, finalized mounting brackets for the diff cage then welded after one last measure up to ensure everything is where it should be. IMG20250228155544.jpg
    I also added a bracket on the outside of the ch***is rails for the axle bumpstop. IMG20250228155611.jpg
    Between the cage and the ch***is is some 5mm rubber sheet and under the square washer to help with isolation and noise reduction.
    From the underside of the ch***is you can see the rubber. IMG20250228155602.jpg
    I will get the last of the welding on the under side when I next drop it all out.
    I think I will mount the engine and trans next then the additional cross members and K member.
    Edit, yes I have put crush tubes in the ch***is for the mounting bolts
  22. 26 T Ford RPU
    26 T Ford RPU
    Very thankful for the HAMB O/T section ...would be sad to miss this. :cool::cool: JW
  23. woodbox
    woodbox
    Cheers mate. At least I know I have an audience of 1!
  24. 26 T Ford RPU
    26 T Ford RPU
    I'm sure there are others but i like to acknowledge good **** like what you do.:D JW
    deathrowdave likes this.
  25. James D
    James D
    Love it. Not sure what makes this non trad tbh.
  26. woodbox
    woodbox
    Jag ifs irs.
  27. woodbox
    woodbox
    I checked in on the mol***es bath this afternoon after getting a whiff of it through the window. The surface of the liquid was covered in foam, which by all accounts means it is working!
    61Cruiser, SS327, Jiminy and 3 others like this.
  28. James D
    James D
    Which are from the 60s and were used on rods in period. Oh well, not my rules. Glad I found the build.
    woodbox, loudbang and 26 T Ford RPU like this.
  29. woodbox
    woodbox
    Welcome aboard.
  30. woodbox
    woodbox
    The factory K member was in the way for the new trans, so in the bin it went!
    But not until I had added an RHS brace and a couple of welds.
    As you can see, for those playing along at home, I have been doing a bit of CAD (chalk aided design) work to give my thoughts some solidity.
    I followed up the CAD with some pencil on a sheet of mdf board before cutting some actual steel.
    If you look real close I have included a basic set up for the trailing arm onto the IRS.
    After a day of grinding, more grinding and welding, more grinding and a trip into town for more welding wire and some cutting discs we have the two pieces of 100mm x 50mm x 3mm RHS with appropriate bends in the required places. These are sitting in nearly the right spots, but I will add 2 pieces in the center and weld before offering up to set the final cut locations........stay tuned.
