Looking for help we have a steel 32 5 w running a fresh build mild hemi and a turbo 350 transmission fitted with a Barry grant demon 98 try power ,starts on the ****on ,idle is smooth ,drives great BUT when you come off the gas i.e. pulling up in traffic ,stoping at a crosswalk engine cuts out ,does restart ok,so we are having to select neutral as we slow down and lift revs ,we have a primary carb center with secondary's for and aft ,fuel pressure ok , we have had the carb set up for about 6 year purchased them new fitted them this year .we are in ENGLAND so we need your help ? Sent from my iPad using The H.A.M.B. mobile app
My friend, you have this question in the wrong place, needs to be in "The Hokey *** Message Board" and when you repost it, state whether trans is manual or automatic. Good Luck.
