Denting a header
Discussion in 'The Hokey Ass Message Board' started by pokey, Aug 14, 2013.
  1. pokey
    pokey
    I have these quarter headers on my 55Chevy and on the driver's side the spark plug boot burns causing me to be stranded. I need to dent it so I can get at least a half inch distance from the boot. How would you guy's do this? I am trying heat tonight then light taps on it to reshape it. What do you think? Has anyone had these problems with the new headers?
  2. willys1
    willys1
    from South Ga
    Socket and a big hammer with or without a little heat , for a neat contour :)
  3. hotroddon
    hotroddon
    What new headers?
    I don't really like beating on my sockets as suggested, so I just use a piece of pipe with heat to a dull cherry red. Then give it a good smack
  4. pinkynoegg
    pinkynoegg
    I just take a body hammer to my headers when they need some reshaping. no need for heat unless they are super thick walled.
  5. Model T1
    Model T1
    That's the way we've done it with our 55-56-57 Chevy's. Quarter inch space seems to work.
  6. 2racer
    2racer
  7. hotroddon
    hotroddon
    I guess it sends on how much of a "BAP" as we in the header industry call it is needed. For a small amount, I agree with you, for something larger, out comes the heat.
  8. pinkynoegg
    pinkynoegg
    yes I am ***uming it doesn't need much of a "BAP" since its just for a spark plug boot. just like you said though, if its something more than that then some other persuasion technique may be needed
  9. Jalopy Joker
    Jalopy Joker
    also, go check Jeg's & Summit for plug wire heat shields or Accel heat resistant plug wires.
  10. Dane
    Dane
    from Soquel, CA
    Don't know about tradition, but these insulators work very well -
    If you dent it you want it to be like this which is why everyone is saying use a pipe or socket -
    5559
    from tn
    I always use an old piece of header gasket trimmed to fit & wedged between plug boot & header--has worked for me since the early 70s
  12. Mr48chev
    Piece of pipe the right size, round steel bar the right size to get the desired shape in the spot you need it. A bit of effort and the dimples will look like they came from the factory that way.
  13. NATESBPD
    NATESBPD
    Like another member said..these ceramic boots slide over the wires..work good..they come in all different colors.
  14. JEM
    JEM
    I suppose if you're beating on 18ga $99 specials, you can get away without heat, but for 16ga you're going to want heat to get a smooth dimple and for 14ga you're gonna need quite a bit of it.
    For a plug wire I'd try to find an insulator or a bendable boot or something, though. Some of what's pictured is good, McMaster-Carr also sells lengths of woven silica sleeving if you want to try to make something.
  15. NATESBPD
    NATESBPD
