Derusting Chrome
Discussion in 'The Hokey Ass Message Board' started by Hellfish, Mar 7, 2007.
  1. Hellfish
    Hellfish
  2. Gigantor
    Gigantor
    Where do you get it?
  3. Gigantor
    Gigantor
    All right - I resd the whole article - VERY COOL! You wouldn't happen to know the best ratio for mixing the wood bleach/Oxalic Acid to would you?
  4. houseofhotrods
    houseofhotrods
    I use wheel acid from our detail shop. We buy it in 5 galllon containers. Works awesome. Any detail supply house has it, pretty inexpensive too. Just don't get it on your clothes, skin or in your eyes!! Tim :)
  5. upzndownz
    upzndownz
    not all chrome is created equal// theres a huge differance between schwinn chrome and most other chrome// so i wouldn't expect that to have anywhere near the results on ford or chevy stuff
  6. polisher
    polisher
    Alliance Vendor
    The acid has merely removed the rust from the surface, it will be back.
    The pits and chinks are evidence that the chrome is broken.
    The worst problem with acids is that they generally remove the chrome and expose the nickel underneath.
    As regards wheel brightener, I consider any shop that uses that stuff should close its doors.
    It destroys aluminum and should be illega
    I've seen more cracks between lug holes on semi's where that stuff has been used than I can count.
    Having said all of that, if it helps you avoid a rechrome job for a year or two, good deal.
    Chrome doesn't come cheap these days.
  7. Hellfish
    Hellfish
    Thanks for your insight Polisher!
  8. I have a coupla schwinns that aren't valuable enough to justify a rechrome, this might make them presentable.
    I would imagine waxing the bageezus out of the parts afterwards would help with the inevitable.
  9. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    I use steel wool and elbow grease.
  10. Shane T.
    Shane T.
    Good ole Coca COla classic and aluminum foil. Try it it works.
    Shane T
  11. BOBBYA312
    BOBBYA312
    from Ala
    S.T.- Please tell me you are not on the clock, playin on Tom's dime. (Just Kiddin). Got the spindle stops yesterday. Thanks D.W.
  12. continentaljohn
    continentaljohn
    Something you want to do if your thinking about using Oxalic Acid. Keep the shit out of the garage and sealed up!!! It will remove rust when soaked or wiped on but will RUST EVERYTHING IN SITE if you have a container open in a closed garage in no time!!!! Use it outside and seal up when not using. I know of a buddy that had a model A just came beck from the stripper sitting in bare metal along with his fully built chassie (bare metal) Well he forgot to send a a part to the stripper so he'll do it in the shop with some "Oxalic Acid" bath. Work great.. Came in the next morning and there wasn't a bare chunk of metal around. It rusted up in less then 15 hours!!!! No shit!!! and it was everything!!
  13. SinisterCustom
    SinisterCustom
    Or Ketcup and alum foil.......
  14. continentaljohn
    continentaljohn
    Chrome does come cheap these day, just not here in the U.S. A company down the street sends parts overseas and back cheaper then he can have it done here, unbeliveable!!!:rolleyes: Oh yea they do secondary operations on parts from overseas!!!:( so parts are ship 3 times!!
  15. Moonglow2
    Moonglow2
    Chrome is a flash coating less than 0.001" thick and is purely decorative. Triple chrome has a copper base, followed by nickel which is where the rust resistance comes from and also the main expense besides the metal-prep labor.
    I quit buying Sears Craftsman when I figured out they stopped doing the copper, nickel, chrome process on their hand tools unless you step up to what they now call the pro series tools. Anyone want some unused rusty Craftsman sockets?(JK)
  16. polisher
    polisher
    Alliance Vendor
    Never ever use steel wool on chrome.
    You'll push steel into the pores and the rust will come back three times as bad, splits the chrome fast.
    Use copper, or a brass wool if it's really bad.
    At the end of the day a good polish will do the job perfectly well.
    It just takes more time but it's worth the investment if you want your chrome to last.
  17. polisher
    polisher
    Alliance Vendor
    Actually works well, the magic ingredient in Coke, or pepsie for that matter is phosphoric acid. Same as in Naval jelly.
  18. SinisterCustom
    SinisterCustom
    Coke works good for freeing up seized motors too. Just pour a little through the sparkplug holes and let it sit a day or two.....
  19. I've always used Never Dull and lots of elbow grease.
  20. Digger_Dave
    Digger_Dave
    polisher; what causes certain chrome(d) items to rust and pit?
    Sometimes I see 50 year old bumpers that have been exposed to the elements most of their life, that come "back to life" with nothing more than some soap, water and polish; then right beside it, a 20 year old bumper with the chrome pealing off.
    Have present day chrome plating methods changed?
    Or are they "cutting steps" to save money?
    What do you recommend for cleaning and polishing chrome?? (that isn't showing signs of rust)
  21. polisher
    polisher
    Alliance Vendor
  22. Once there's rust on the surface of the chrome you cannot
  23. Once there's rust on the surface of the chrome you cannot get rid of it. Chrome itself is porous - that's why good chrome jobs are first copper plated then nickel plated and then chrome plated. Hence the phrase "Triple plated" Cheap jobs miss out the copper and nickel layers. It's then just a matter of time until the rust sets in.
  24. Digger_Dave
    Digger_Dave
    Thanks polisher; time to throw out all the "Super chrome polishes!"
    (that aren't from you! :D)
    BTW - your web site is a real "gold mine" of information!
  25. ZZ-IRON
    ZZ-IRON
    from Minnesota
    I was searching Google for a rust remover & Oxalic acid and it got me to this old Hamb thread SinisterCustom's post # 13 ketchup & aluminum foil balled up to remove rust
    Try a TEST PIECE FIRST on chrome it can scratch but the rust comes off, squirted ketchup on the part & rubbed with the foil, kept rotating the balled up foil and washing the black mess off with water now and then, it worked pretty good on rusted bare metal & a rusty peeling chrome bumper :) easy on the hands & easy clean up
    some photos before on another car
    after 5 to 10 minutes
    spent 5 minutes on the bumper guard
    not to bad for the time spent
