Technical Designing Gauge Faces ????????????/
Discussion in 'The Hokey Ass Message Board' started by brigrat, Feb 27, 2015.
  1. brigrat
    brigrat
    from Wa.St.
    Trying my hand at designing a set of custom, one off gauge faces. As we speak a HAMB member is photoshopping my idea onto paper, my question is how do I take it from paper and make it happen on a metal face, what process is used to stencil it on? Can it be done without special machines and printers? Thanks!
  2. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Usually a silk screen process...
  3. brigrat
    brigrat
    from Wa.St.
    Silk screen, any HAMB members do that kind of thing? I ***ume you paint the background color (black) than Silk screen on the numbers/letters? What do Silk screeners like as a format for the design, or am I over thinking this?
  4. tb33anda3rd
    tb33anda3rd
    i don't know if this would work and i have never tried it but.....my wife bought heat transfer paper for the printer and transferred a photo on a t-shirt. i wonder if it would work on a piece of metal or thin plastic?
  5. PKap
    PKap
    from Alberta
    I just redesigned my tach to look like a clock for my 46 Ford. My sign maker is printing it on vinyl and I will overlay the existing face plate. Not as traditional as silk screening, but I can exactly match the look of my other gauges, and it is relatively inexpensive.
  6. Bulletnose26
    Bulletnose26
    Try looking into Dye Sublimation.
    The printed inks are heated into a polyester coating, on thin aluminium blanks.
  7. If you use vinyl, make sure you use top-quality stuff like 3M or equivalent that's rated for heat/sunlight. Silkscreening is the best method. Try a local sign shop, most can take camera-ready art and make a vinyl overlay using good vinyl with a laser cutter. This isn't really something you can do at home on a standard printer and have it hold up, BTDT....
  8. Phillips
    Phillips
    I have a customer that prints faces directly on aluminum sheet using a UV inkjet device, some of his parts go in high end restorations such as Ferraris.
  9. chrisp
    chrisp
    You can print your own water decals and lay them on your painted gauge faces. You just need to be meticulous when setting them.
  10. 69fury
    69fury
    from Topeka
    There's also a thread around here on how to etch your own br*** cowl tag/id tags/etc.. Br*** etched gauges could look cool in the right dash....-rick
  11. raprap
    raprap
    from Ohio
    Hey guys, Any modern printer can digitally print on most substances up to 1" thick. If you have clean art in Illustrator save out as a AI or PDF file formatt and provide a clean substrate. It's simple, fast and should be cost effective.
  12. treb11
    treb11
    Isn't there a gauge maker that will print your design? But memory says it is/was Dolphin = Hoffman.
  13. brigrat
    brigrat
    from Wa.St.
    Thanks for all the info guys, will have to check each one and see which works best for me. Will update later in the project....................................
  14. brigrat
    brigrat
    from Wa.St.
    "Isn't there a gauge maker that will print your design? But memory says it is/was Dolphin = Hoffman."
    Trying to byp*** the gauge makers, way to much $$$$$ for this build. Besides Dolphin = Hoffman = Junk that smells Fishy.........................
    kiwijeff likes this.
  15. David Gersic
    David Gersic
    from DeKalb, IL
  16. brigrat
    brigrat
    from Wa.St.
    There's only 2 colors, Black & White, Black being the background, White being the letters/numbers. Thanks for the links will check them out tonight!
  17. metal man
    metal man
    Just food for thought... A good sign painter can do them by hand. Joshua shaw did a set for a friend of ours a few years ago and I think they look really cool.
  18. brigrat
    brigrat
    from Wa.St.
    Well we do have a local Sign painter that is talented enough, will work for Beer, but most of the time what you get isn't what you wanted!
  19. metal man
    metal man
    You could always send them to Josh. He's damn good, and reliable / trustworthy . Long time HAMB member in Cincinnati Oh.
  20. You could also design it here http://frontpanelexpress.com/ using their free software and have it mailed to you. The possibilities are endless.
  21. fordor41
    fordor41
    make sure you clear coat them first with clear acrylic spray.
  22. chrisp
    chrisp
    Yes, I forgot to mention that.
  23. BamaMav
    BamaMav
    from Berry, AL
    I'm gonna have to remember that one, describes them to a T! :D
