What do you guys think of the grill? I have a little adjusting to do on the teeth an my next step is to put 52 ford turn signals on it. If anyone has a set let me know.
Grill going to be cool,but looks a little crowded right now,either need to remove a couple of teeth or remove area of fender were turnsignal mounts and spread teeth out.
that looks good on that 53!! I think tho with a little centering it would look better. My buddy ericl1951 here on the hamb has vw bumbers for teeth as his grill and it looks really cool
Thanks guys! Appriciate the comments. I think the shadowing in the pic an angle make them look alot more off center than they really are. The teeth arent original desoto they are actually a cast set off ebay. they need sanding an some polishing
Eleven teeth seems like a couple too many in that area unless, as mentioned before, you remove the turn signal housing.
You're on the right track! I like the idea of removing the turn signal housings and spreading them out. You could then put the signals IN the outer teeth.
I am in the grill thinking process right now to. I couldnt decide if I wanted a tube grill, or teeth for the 56. I just received over 100' of FREE 3/8" 304 SS tubing, so likely tube grill coming (thanks Uncle . Either way, I saw a lot of folks using these also for teeth, cheap and available for anyone else looking at teeth. VW Bug bumper guards around $8 each http://www.jalopyjournal.com/forum/showthread.php?t=318929
this is vein's here with vw bumperets http://www.jalopyjournal.com/forum/album.php?albumid=5113&pictureid=172356
