Desoto water pump conversion
Discussion in 'The Hokey Ass Message Board' started by Jeff Smith 700, Jun 26, 2011.
  1. Jeff Smith 700
    Jeff Smith 700
    I have read a few post about putting a big block mopar water pump in a desoto housing. I am considering converting my 55 291 housing to accept the mopar pump as a diretct bolt on. The only thing stopping me is nobody has said how it actually works. fitting is one thing, cooling is another. I hope somebody out there knows how well it works or doesn't work. Otherwise I need the name of a good re-builder to send my desoto pump to. Thanks
    Jeff
  2. jimi'shemi291
    jimi'shemi291
    Jeff, yes, it can be done using a MoPar 383 water pump, and apparently at a pretty significant saving, if you have a few tools and follow the pointers in Rabid Whippet's thread of October 2009. Search here:
    1952 Desoto Water pump
  3. Jeff Smith 700
    Jeff Smith 700
    Thanks guys. I can go ahead and bore the pump housing out and shift the bolt pattern for the newer style pump. And thanks for the AAA tip!! 10% means 4 bucks is 4 bucks!!
