DESPERATE: I need a transmission EXPERT
Discussion in 'The Hokey Ass Message Board' started by Carfanatic, Dec 10, 2010.
  1. Carfanatic
    Carfanatic
    Well at full throttle it only shifts when you let off the throttle.
  2. Verbal Kint
    Verbal Kint
    from Washington
    sounds vacuum related
  3. Mr4Speed
    Mr4Speed
    If it's the same with the 1-2 and 2-3 shift i asume it's not getting enough oil pressure from the governor to operate the shift valve's.
    Some possible causes:
    Leaking governor pipes
    Plugged governor filter
    Worn out governor shaft/bore
    Governor valve sticking
  4. Mr4Speed
    Mr4Speed
    At full throtlle there won't be any vacuum!
    And because of that it will have maximum modulator oil pressure workin against governor pressure from moving the shift valve, and so delay the shift.
    In this case, when you let off the throttle vacuum will come back and modulator oil pressure drops.
    Governor pressure is than able to push the shift valve against spring pressure only and it will shift.
