Technical Details that you're kinda weird about.
Discussion in 'The Hokey Ass Message Board' started by NAES, Nov 26, 2018.
  1. oldsman41
    oldsman41
    Wiring. Drives me crazy to see a trash load of wires running all over the place.
  2. brigrat
    brigrat
    from Wa.St.
    Paying thousands for a paint job only to see 6 months later all the sanding marks and dents missed.....................................................................
    The37Kid likes this.
  3. wraymen
    wraymen
    I foresee some pranks headed your way..............better lock up that ride.:D;)
    loudbang and lothiandon1940 like this.
  4. Blue One
    Blue One
    from Alberta
    It’s probably a look at me I got new tires thing :D
  5. wraymen
    wraymen
    That ego trip has got to be a short one, 3 miles maybe.
    loudbang, blowby, VANDENPLAS and 2 others like this.
  6. chevy57dude
    chevy57dude
    lothiandon1940 likes this.
  7. rockable
    rockable
    Neat welds. If you can't weld neatly, learn to dress them up with a grinder but don't leave "chicken doo" welds on your cars, people.
    Boneyard51, loudbang, tinsled and 3 others like this.
  8. chevy57dude
    chevy57dude
    ^Right on. Bird**** welds = r*t rod rash^
    loudbang, rockable and lothiandon1940 like this.
  9. XXL__
    XXL__
    Window crank position. With window all the way up, looking from driver's seat at driver's door, crank points to 2:00... mirrored on p***enger side.
  10. How about 1/2" aluminum gas line, all bent up every inch, then connected to rubber hose that looks like somebody bit it off, secured by worm gear clamps that are too long, and kinked over and down ?:eek::eek:
    Just Gary likes this.
  11. LM14
    LM14
    from Iowa
    Not carrying a theme all the way thru a build. Not as big of a problem here, but in other automotive areas dudes build half pro street, 1/4 pro touring and 1/4 custom. Big blown engines in stock restorations. Mix and match. Make up your mind! Drives me nuts.
    SPark
    40FORDPU, rdscotty, loudbang and 5 others like this.
  12. The37Kid
    The37Kid
    Hose clamps that are too long, rear axle/spring U bolts that are too long, sheet metal screw tip that is visible. Above all, the area that you forgot to paint. Bob
  13. RMR&C
    RMR&C
    from NW Montana
    Door/panel gaps. 20k on a custom paint job and the gaps are all out of whack.
  14. Hnstray
    Hnstray
    from Quincy, IL
    those screws are fillister head, not flathead..........:eek:
    loudbang, Hemi Joel, rockable and 4 others like this.
  15. Moon50F3
    Moon50F3
    Wiring needs to be neat and loomed up. Plug wires routed well. No matter how good everything else looks, I always wonder what else is wrong when folks have unkempt wiring.
    loudbang and Just Gary like this.
  16. mgtstumpy
    mgtstumpy
    When I converted my OT 66 Fairlane to RHD I used a local RHD cowl forward with skirts and frame rails as well as side scuttle panels forward of the front door hinges. RHD heater box bolts right in as does steering and brakes. Plus the wipers swept to the RH side. I wanted to retain the OEM look and as such all the visible factory spot welds were intact. Where other welds were visible or not I finished them so it appeared totally original. Believe me it was a lot of work, even the dash, shifter and instrument configuration were mirrored to RHD format as was the parking brake pedal. I didn't do the console, too much work and no one would have noticed anyway. I even moved the radio aerial across to the opposite RH front fender. Some think I was **** by doing so much work. That separates the men from the boys.:D
    All the 'Know it alls' went over it and commented that Ford had never produced a convertible Fairlane and that I had done a great job cutting the roof off and lengthening the doors etc etc. :rolleyes::rolleyes: If they'd noticed everything about the body was different, fenders, bars, hood, grill. Even the 390FE and C6 which wasn't offered locally in the smaller Fairlane; all we got were poverty pack 4-door sedans, nothing else.
  17. Just Gary
    Just Gary
    Adjacent hard lines that aren't parallel.:mad:
    I spent hours getting my Chevy's brake m/c lines parallel:
    40FORDPU, loudbang, mgtstumpy and 5 others like this.
  18. Roothawg
    Roothawg
    I have a weird fetish for removing casting flash. Can't stand it. When I was in high school, I was broke all the time, so I filed and ground everything. I could work in the shop for hours and when I did finally get around to painting parts, it was a better finish. It just carried forward.
  19. Love's me some Shiner Bock
    texasred likes this.
  20. Zuffen
    Zuffen
    from Sydney
    Washers installed upside down.
    They do have a radiused side and a sharp side where they are stamped out.
    Sharp side down!
  21. HOTRODPRIMER
    HOTRODPRIMER
    Fake patina, dirty whitewalls, chain steering wheels, astro turf, splash graphics, cry baby dolls, fuzzy dice, mud flaps, car alarms, power parkers, electric fans running after the car is parked, bright colored spark plug wires, long shackles, tweed interiors, billet wheels, chewing gum on your shoe & your carpet, bird ****, and people that write " Wash Me" on your dirty car. HRP
  22. Roothawg
    Roothawg
    Anything else? Bumper stickers are gay and especially ones that are off center or crooked.
  23. adam401
    adam401
    Thanks for pointing that out. I never knew that. I even googled it after. Now Ill never forget. Its cool what you can learn here.
  24. i.rant
    i.rant
    Mismatched valve stem caps can make me hyperventilate with anxiety..:rolleyes:
  25. Slopok
    Slopok
    Seems like a lot of us have issues!o_O
  26. low budget
    low budget
    from Central Ky
    I like what you did but Im more of a if it aint broke dont fix it guy most of the time, It would have leaked if I had done that:D
    Dont know why but this reminds me of one morning I was trying take my time and "create" myself a "perfect" looking over medium fried egg for breakfast, when my wife walks by and takes a fork and quickly mutilates my masterpiece just for laughs:mad:...it was pretty funny even tho the joke was on me, but still.....:D
  27. deathrowdave
    deathrowdave
    from NKy
    Shiner Bock or Skiner Back ? I guess it depends on the county farm where you spent a vacation .
  28. stanlow69
    stanlow69
    People who display there vehicle with the hood all the way up. A door that is opened up all the way or worse, both doors. And the trunk lid also opened up all the way. It reminds me of an airplane.
    robracer1, lothiandon1940 and i.rant like this.
  29. 41woodie
    41woodie
    Corrugated universal radiator hose makes me crazy. Even if you have to join parts of two different hoses it looks better than the universal stuff
  30. The37Kid
    The37Kid
    Only thing that looks dumber is a row of like cars, (think small wild horses by Ford) with the hoods all up, looks like feeding time at an alligator farm. Bob
    wackdaddy, Saxman, stanlow69 and 5 others like this.
