determining the rearend on my 54 Ford
Discussion in 'The Hokey Ass Message Board' started by Martino, Jun 20, 2013.
  1. Martino
    Martino
    I was told this rearend came out of a Granada. It doesnt have a tag on it. Any help!
  2. Without a tag it's a tough call,,It may be a Granada or a Maverick. HRP
  3. Martino
    Martino
    My concern is when I need parts; Brakes, bearings, Internals etc.
  4. The old bearings will have a number on them and I'm willing to bet in the parts catalog the Maverick,Mustang and Granada share the same brake shoes and wheel cylinders. HRP
  5. Martino
    Martino
    Sounds good. With the 239 and 3 speed linked to this rearend taking off in first gear is tough. Without a tag I have to do the old school method of counting the tire rotation to drive shaft. I have no idea what the gear ratio is?
  6. hoodprop
    hoodprop
    Looks like a Dana 44 10 bolt cover. If I remember right clean the right lower corner of the diff it will say 44 and i belive to find the axle ratio clean the right tube should have some numbers on it.
  7. Martino
    Martino
    I'll check it out for any signs of Indentification in those areas.
  8. Jalopy Joker
    Jalopy Joker
    not a Ford Granada rearend
  9. Martino
    Martino
    Obvisously it's going to take more investigation.
  10. Fenders
    Fenders
    Gear ratio:
    Find out what the axle is from and what ratios were available.
    Jack up ONE rear wheel, trans in neutral, turn the tire TWO turns, count the turns of the driveshaft.
    If the driveshaft turns like 3 and 3/4 (for example), it's a 3.73 -- if it turns 3 times, it's a 3.07
    Check which ratios were available so you will get the correct answer.
  11. Martino
    Martino
    Thanks Fenders
  12. George/Maine
    George/Maine
    looks like a rear end out of a Ford 53 pu I have one about 3.78 less the 4 to 1 .
  13. Take a photo of the front of the housing. HRP
  14. Martino
    Martino
    I'll take a pic of the pig from the front when I get home.
  15. hoodprop
    hoodprop
    Looks like the dana 44. If it out of F100 51-53 it may be a 3.92 gear which was common in a truck axle. If it was a granada it would be a 9 inch i belive. But that is not a 9 inch housing. Dana 44 were use in jeep and early f100. Corvettes used them as well. As far abrake hardware goes pull a drum off see if the are self adjusting. If they are self adjusting you have a newer style dana 44
  16. onetrickpony
    onetrickpony
    from Texas
    It looks like a Ford 8.8 to me. Look at this rear cover:
  17. hoodprop
    hoodprop
    Onetrickpony would be correct didnt see that there is no fill plug on the cover. in that case that came in a ton of ford cars. Crown vic. explorers, mustangs. gear ratio vary for 3.08 to 3.42 3.55 4.11
  18. Not all Granada's had a 9" rear end. HRP
  19. Martino
    Martino
    I took a pic. To much sunlight.
    But I jacked up rear tire. It turned once. The driveshaft turned 1.25
  20. Martino
    Martino
    Saw a thread about a guy asking about gear ratios in 9 inch rear ends. Lincoln's and T-Birds from the seventies had 2.47 and 2.50 gear ratios. Well I know much.
  21. gimpyshotrods
    gimpyshotrods
    Cover is the wrong shape to be a Dana 44.
  22. APACHE FS
    APACHE FS
    Looks like 8.8 to me...but most of those have two small notches on the bottom corners of the cover???
  23. gimpyshotrods
    gimpyshotrods
    The cover does look a bit like a 8.8, but the housing, where the tubes slide in, does not extend very far away from the main body. I was just working on an 8.8 from a 1991 Ranger, and it had about 3" of housing around the tubes.
  24. Martino
    Martino
    Here is a pic of the front. But the lighting didnt help much.
  25. Set the camera to forced flash. That will solve the light issue.
  26. Martino
    Martino
  27. George/Maine
    George/Maine
    Look at how the driveshaft bolts to rear end 50 ford pu they are not held on with u bolts,they use bolts instead.
    Granada are like 9" the ceneter chuck is removed out the front as a whole unit.
  28. Martino
    Martino
    The u joints are held on with u clamps. Once I determined the ratio since the previous owner said the rearend was from a Granada I tend to think now it came from a Lincoln Versailles.
  29. junkyardjeff
    junkyardjeff
    I think the 6 cylinder granadas had that type of rear end,all the ones with V8s had a 8 inch.
  30. Martino
    Martino
    This is the thread from dragass about a 2.75 rearend with a 2.47 ratio.
    Anyone here running 2.47 rearend gears?
