Technical Deuce 1932 32 Ford Firewall Wiring Routing
Discussion in 'The Hokey Ass Message Board' started by marfen, Mar 7, 2015.
  1. marfen
    marfen
    from sask
    I'd appreciate any ideas where to route my forward engine/lighting wiring harness from my drivers side fuse box through the firewall or maybe below. I need a bit of input before the holesaw comes out. Got 3 pedals , master cylinders below the floor. thx
  2. marfen
    marfen
    from sask
    Fenderfree, lighting wiring will go along inside of frame rail.
  3. HOTRODPRIMER
    HOTRODPRIMER
    I prefer to fill all the holes in the firewall and route the wires down the inside of the firewall and down to the frame so they are not exposed,,to me a bundled of wires are a distraction . HRP
  4. harleycontracter
    harleycontracter
    I do what Danny said too. Doing that now as a matter of fact. I have 3 grommeted holes one on left and one on right side where the floor goes from flat to upwards angle and 1 on the botton front of the firewall. Used a black cloth wire loom to go from grommets to the locations I need to get to . Hope this helps. Almost everything comes up from bottom. Also made a bracket and mounted fuse block on p***enger side of cowl up high. Can't see it and easy access.
  5. marfen
    marfen
    from sask
    thanks for the tips. I'm guessin the wiring goes behind the kick panel
  6. Andy
    Andy
    There is a slot between the firewall kick up and the subrail at the A post. I run the wires down the cowl and under the floor and thru the slot. If you are going to box the frame, maybe put a piece of tubing in the rail so wires can be run thru it.
