Technical Deuce frame 39-pedals
Discussion in 'Traditional Hot Rods' started by 3wmike, Sep 24, 2022.
  1. 3wmike
    3wmike
    Do anyone have any good ideas how to put 39 pedals clutch and brake into an original deuce frame, the angle seem not to be ok
    Thanks
  2. alchemy
    alchemy
    Modify the K member leg?
    303racer likes this.
  3. FritzJr
    FritzJr
    The '39 pedals are a great choice for '35 through '38 Fords but do not fit very well in a '32 frame.
    rusty valley likes this.
  4. Jethro
    Jethro
    Didn't Brian B*** use a 39 K member with 39 pedals in a 32 frame? If I remember right it looked really good....but all B*** stuff looks good!
  5. Not an answer to your question but thought you might find it interesting to see how I set up my AVATAR. It uses the original '32 pedals and a bracket to hold the master cylinder. The bracket is welded to a plate that bolts to the crossmember. I don't remember drilling any extra holes or welding on the vehicle. I made the leverage on the linkage match the leverage on a '39 pedal ***embly. The master cylinder fills through the original hole for the battery. I moved the battery to the right side but with todays smaller batteries I might choose a different location.
    Charlie Stephens
    C69A likes this.
  6. junkman8888
    junkman8888
    Outstanding work, a lot of careful thought went into that bracket.
  7. nobby
    nobby
  8. Mr48chev
    I took the dark out of Charlie's photo so it can be seen easier. Brake bracket 32 (2).jpeg
    Rex_A_Lott likes this.
  9. 3wmike
    3wmike
    Thanks for tip, I maybe has to look for original brake/clutch pedals
    BlueNotes likes this.
  10. Yes, do that and take a look at the hydraulic brake conversion kit from the Early V8 Garage. They make kits that doesn't require any cutting, welding or even drilling. Here's a link to their website:
    http://www.earlyv8garage.net/
  11. What about some F1 pedals with the K member?
  12. banjorear
    banjorear
    Another way to think about it to use '32 pedals and the brake actuator mounted behind the K as linkage to activate a rod in a master cylinder mounted behind the K.
    If I get under my car, I'll take a pict of the similar set we used to do.
  13. krylon32
    krylon32
    from Nebraska
    Another vote for the Early Ford V8 Garage. The Lacy boys will set you up. 626-337-1175
    Andy likes this.
  14. overspray
    overspray
    I think I saw some time ago, the hot deal was a 39 Ford pickup crossmember with pedal ***embly grafted into the 32 frame.
  15. dln1949
    dln1949
    You can always build your own.
  16. First Bishop/Tardell AV8 book has some info on using '39 pedals with a '32 K-member, however if The Lacys' produce such a kit it will be well worth the time saved and money spent...
    Andy likes this.
  17. Dedsoto
    Dedsoto
    from Australia
    J.Ukrop likes this.
  18. banjorear
    banjorear
    Someone is selling a K member leg that is modified to use '39 pedals in the parts section.
  19. Warmer 1932
    Warmer 1932
    Why do that when a set of original pedals works great. Reweld lever to bottom of pedal mount a master cyl adapter to bottom of k. Very clean and neat.
    alchemy likes this.
