Deuce Fuel tank on a Model A
Discussion in 'The Hokey Ass Message Board' started by Von Rigg Fink, Dec 27, 2009.
  1. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I would like to talk to those who have done this mod.
    I am currently building a full fender Tudor and am researching my options for fuel tank placement.
    I would like to talk to those who have done this modification.
    I would rather the discussion be about this , and not any drama please.;)
    I have looked into the saddle tanks..Im NOT going that route..please lets not go there.
    I have looked into running a tank inside the car..Please lets not go here also.
    and NO im not going to use the stock tank..I cant and dont want to get into that either
    I know that Dagles offers a "kit" to run the 32 style tank on a model A frame, anyone use it? or others?
    Negative Opinions on the looks, Im not asking for that either..please.
    What im after is pictures of how this is done on a stock A frame, how well it went. and what modifications if any to make this work right. Any opinions on the "kit" from Dagels or any other sources would also be great,and how they attach to the stock A frame, and what the cost was for you to make this mod.
    Thanks:cool:
  2. Ralph Moore
    Ralph Moore
    Don't know if this will help or not, but I bought a Duece fuel tank from a guy that decided to restore his tudor sedan instead of hot rodding it. Anyway, the guy he bought it from had a fuel tank mount made for the duece tank to fit the A frame. I got it in the deal and don't plan to use it and thought some pictures might help you out. Not sure how he planned to mount this because I don't have an A frame to mate it up to.
  3. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Ralph you got a PM
  4. Crusty Nut
    Crusty Nut
    I just did it. The kit is over priced IMHO. I bought a pair of '32 rear frame cut offs on ebay and a vintique tank and frame covers. I made my own spreader bar since I wanted a beefy one to build a trailer hitch into.
    The frame covers need to be widened about 1.5"s to meet the fenders. I just made it up as I went and it worked out fine. I also needed to build a small flange to weld into the body to hide the sending unit. But I've seen some that didn't.
    Feel free to contact me for more info.
  5. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Crusty thats sweet..
    I will be talkin to ya.!
  6. Ralph Moore
    Ralph Moore
    Here's the wheel pics
  7. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Ralph..that looks like the Dagels Deuce to model A frame set up..probably for a 30-31..because they say they wont weld up one for a 28-9 because of too many variables.
    unless the previous owner did the work for a 28-9,,either way im resourceful enough to make it work if things work out.
  8. mikeco
    mikeco
    from virginia
    I wanted to do the same thing to the wife's 29 but haven't had much luck finding anything. I'd be interested if ya find something!
  9. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Mikeco..check Dagels..they do have a Kit..i was looking at theirs and the alternatives of just making it myself
    http://www.dagelsstreetrods.com/
  10. Toner283
    Toner283
    Here are some pics of ours. it is a coupe but the idea is the same. Frame horn covers are in the works, just have not got that far yet.
    Here is a link tot he build thread. http://www.jalopyjournal.com/forum/showthread.php?t=348159
    If you have any questions feel free to PM me. Later, Tone
  11. Von Rigg Fink
    Von Rigg Fink
    from Garage
    thanks Tone..i saw your A on another thread..looks good.
    I will check out the build., thanks for the link
  12. Toner283
    Toner283
    I have about a zillion more pics if there is anything you want to see up close or in more detail.
  13. Von Rigg Fink
    Von Rigg Fink
    from Garage
    what would you say you had to put out $$ to get everything for this set up..ball park cost
  14. cretin
    cretin
  15. Von Rigg Fink
    Von Rigg Fink
    from Garage
    thanks ******..any info is good info at this point
  16. Crusty Nut
    Crusty Nut
    Von rigg, here is a couple more pictures in progress
  17. mikeco
    mikeco
    from virginia
    Thanks I did see that one, but to fit a 28-29 took "considerable mods" unlike the 30-31 kit & for the $ just thought there may be a better idea.
  18. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Thanks Crusty
    I think i might even be able to tuck it up even further.
    Im running stock Rear X member, and coil overs..those pictures give me the jist of it.
    thanks again
  19. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Agree, there are better ways..I will probably not go "Kit" unless it lands in my lap cheap. (unlikely)
    and even if it did..it would get modified im sure
  20. Crusty Nut
    Crusty Nut
    Yep, I kept the rear spring 7"'s back from the rear end (or whatever the stock spec was for a '32). With coilovers I'm sure you could tuck it in more.
  21. Von Rigg Fink
    Von Rigg Fink
    from Garage
    kickin' it up for the night crowd
  22. yngrodder
    yngrodder
    I built my own, Got a set of horns another guy cut off,
    Bought a spreader bar and a tank from Speedway. bolted them all togeather and jacked and blocked them up until it looked good then tack welded it in place. pulled the fenders and body back off and then welded it solid. Looks alot like the one ralph posted. I still have not made the frame horn covers.
    I have about 340.00 in it. (The tank that I used it a polt tank with a fibergl*** cover that TANKS makes)
  23. Toner283
    Toner283
    We bought stub rails from Tanks inc. they were about $60/pr. http://www.tanksinc.com/index.cfm/p...ategory_id=81/home_id=59/mode=prod/prd109.htm The frame horn covers were about $150/pr and the spreader bar was about $75. the tank we have is a 14.5 gallon tank & it was about $400. So that is just under $700.00. Usable used deuce stuff up here is non existent so we had to buy new repop stuff.
    Took maybe 12 hours to fab up the mounts & get it all installed. as you probably know when you build an "A" there are always 3 things that want to occupy the same space in any given area. Hope these pics help a bit. ignore the C clamp in the first pic, it is a temporary stop for the rumble lid. The rails are not on the same angle as a deuce, we did the same as yngrodder, we moved it around until it looked "right".
  24. paco
    paco
    from Atlanta
    Looks right at home ....
    Paco
  25. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Thanks i saw the tanks for a bit less then $400..and was watching one on e-scam..i have some time to work this out and spread the cost..I think im sold on it. It will cost a bit more than my original idea, but it think its worth it. And it looks right and possibly get some tumbs up from those in the traditional group
  26. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Hey any HAMB vendors out there making this work for us?..I sure would rather support you guys than any one else..speak up or PM me..would like to see what you have..or can get
  27. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Thanks to HAMBer Ralph Moore..i will be sporting a Deuce tank on my 28 A Tudor ..
    Thanks Again Ralph, cant wait to get it, and mock it up
  28. Kevin Lee
    Kevin Lee
    Super Moderator
    Check out this solution by metalshapes.
  29. Von Rigg Fink
    Von Rigg Fink
    from Garage
    nice finishing touch for a coupe..and once the rail covers are on it i bet it flows really nice
  30. We did 3 or 4 of them when I worked at the shop. They were on Pete and Jake frames and a bit clunkier than what is pictured here. Buy the steel frame horn covers. I had one pair of fibergl*** covers in my hands and they were pure junk.
    Rich B. likes this.
