History Dick Dean score
Discussion in 'Traditional Hot Rods' started by InstantT, Oct 7, 2017.
  1. InstantT
    InstantT
    from SoCal
    When my grandpa died, my grandma said I could have all the car parts in the garage. Most of it was generators and stuff he tore off v8s for racing. There was some pretty cool stuff in there and I had to wait 15 years for my uncle to move his stuff out so I could get to it.
    I found this little tailpiece from a dragster in there. My gramps owned U.S. Speedsport and **** Dean would come by and build the aluminum bodies while gramps built the ch***is.
    So here it is. The last remaining collaboration between my gramps and **** Dean. Found!!
    [​IMG][​IMG]
    Sent from my LGLS992 using The H.A.M.B. mobile app
  2. Corn Fed
    Corn Fed
    Cool peice even without the **** Dean history.
    InstantT likes this.
  3. InstantT
    InstantT
    from SoCal
    I agree. My dad told me **** Dean built it. I couldn't believe it. Then he showed me a U.S. Speedsport ad that said "aluminum bodies by **** Dean".
    Wowee! It is awesome.
    I also found a new set of airheart disk brakes with early ford adapter flame cut by gramps.
    Those WILL go on something someday.
    biggeorge likes this.
  4. InstantT
    InstantT
    from SoCal
    I also got the U.S. Speedsport drillpress with the stand welded up in the shop. I had to replace the motor, but if I ever have to spend thousands to fix anything else, I'll do it.
  5. InstantT
    InstantT
    from SoCal
    It's going on the wall in the house. My original plan was to sand off the filler and clearcoat it, but now I'm thinking I should just clear over the filler and display it "as found".
    What say you?
    biggeorge and 3340 like this.
  6. biggeorge
    biggeorge
    As found!!
    You can clean it up if you ever want to build something around it.
  7. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Cool piece, but it won't be outside and doesn't need clearcoat protection. IMHO, as soon as you clearcoat genuine old paint/patina, you'll totally ruin it. It becomes "new" and looks like someone just worked up phony patina like that Gas Monkey Garage glossed up Olds.
    biggeorge and InstantT like this.
  8. atch
    atch
    ^^^^^ x2.
    Oh, yeah; don't touch that thing. Especially don't sand any filler off of it.
  9. InstantT
    InstantT
    from SoCal
    I mostly wanted the clear so it would be easier to dust[emoji4], but it's probably best to leave it alone.
  10. atch
    atch
    Use a feather duster.
