Did they make a magnesium V8 Halibrand quickchange ?
Discussion in 'Questions & Suggestions' started by model40man, Feb 5, 2004.
  1. model40man
    model40man
    I was wanting to know if anyone knew if Halibrand made a V8 quickchange rearend out of magnesium ???
  2. You will probably get an answer quicker if you post on the main board..and do an INTRO first.
  3. BenD
    BenD
    Alliance Member
    Yes on the intro, and not sure on the V-8 but I do know they made a magnesium centersection called a "no-change" which is really just a stock mag banjo housing.
  4. marq
    marq
    Even if they Did dont bother trying for one,magnesium over a period of years will take in water and rot from the inside and you wont know till it's too late.Very strong light material that is a bugger to machine due to it catching fire and burning bright white hot.It has a usable shelf life sensibly in car/motorcycle aplications 10-12 years after that it should be scrapped due to safety in wheels axles brakes hubs and so on.We recently had a machine shop here in the uk go up near the airport,they were machining a piece of 8x4 sheet and the bloke went off to tea leaving the cnc going and it ran out of coolant.The factory floor was still burning 2 days later leaving a 15 foot wide by 8 foot deep crater in the concrete.Like i said it burns hot and for that reason not a lot of people will machine the stuff...............Mad Marq
  5. 296 V8
    296 V8
    from Nor~Cal
    Yes but thay are rare and you should do a intro befor thay get all pissy and bitchy. Got a 33 or 4 ? or 40 model cars? [​IMG]
