Dies when Idiling
Discussion in 'The Hokey Ass Message Board' started by Encinitas4, Jan 30, 2012.
  1. Encinitas4
    Encinitas4
    Trying to help a friend of my wifes out. She got a 68 mustang, inline 6 single barrel autolite. When she gases it car starts fine as soon as it idles it dies. I looked at it, fuel filter is fine getting gas. Air, maybe, when she showed up i took the air filter off to look at the carb started it and it ran fine for a good 5 minutes. What am i missing here?
  2. Abomb
    Abomb
    Idle air mixture screws too Lean ?? Timing slow ?? Plugged airfilter ?? Float level low ??
    Those are the things I'd start with.
  3. drdoom
    drdoom
    from new jersey
    i do remember a problem , the carb. would loosen up between the base and the body, remove air cleaner and see if the carb. seems loose if so remove and retighten the body to base
  4. 2OLD2FAST
    2OLD2FAST
    from illinois
    Or the other way ,needle & seat bleeding over .. does it smell rich? Points going bad? need more info..
    dave
  5. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Mine was doing the same. Pulled the mixutre screw, blew some air in until gas came out carb. Put the screw back and its been fine since then. Guy said it was a common fix for that trouble on an edelbrock, might work for you too
