Technical Differancein 1948 Ford convertible frame&coupe frame
Discussion in 'Traditional Customs' started by David Hubbs, May 26, 2023.
  1. David Hubbs
    David Hubbs
    I have a 1948 ford convertible with no****le and a 1948 ford coupe with****le. I was thinking of swapping frames. Is this possible? Looks like diamensions are the same. Is the 48 convertible frame heaver then the coupe and sedan frame. I know 1940 ford convertible frame was heaver to support body below door. Thanks for any help.
  2. LOU WELLS
    LOU WELLS
    from IDAHO
    The Convertible Frame Is Made From Slightly Thicker Metal But The Dimensions Are The Same....Proceed...
  3. David Hubbs
    David Hubbs
    If I use the coupe frame with little thinner metal will it cause problems with doors and top operation?
    LOU WELLS likes this.
  4. treb11
    treb11
    Unless the convertible frame is rotted, why not just get a new****le that matches the numberson the frame?
    Tow Truck Tom likes this.
  5. Bandit Billy
    Bandit Billy
    Having owned a lot of rag tops, If you swap them, I would reinforce the frame a bit. Especially in the center, a good plate across the trans mount area below the frame is nice and I would maybe do some boxing around the cowl support to prevent cowl wobble. It may be just fine without any of this, but this is what I would do if it were mine.
    LOU WELLS and GordonC like this.
  6. gimpyshotrods
    gimpyshotrods
    What state are you in?
  7. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    Convertible frames had extra reinforcement to make up for the lack of a roof. The sedan/coupe bodies depended on the roof as part of the structural strength that helped prevent body twist and distortion. If using a convertible body, you should use the matching type of frame. All body types will fit on either frame, however.
  8. David Hubbs
    David Hubbs
    Thanks with all your help. I will just bond the****le.
