Technical Difference between '39 Ford and Mercury Transmission
Discussion in 'Traditional Hot Rods' started by 28A, Nov 13, 2020.
  1. Howdy! I've got a '39 Mercury trans in my Model A and wondering if there is any difference between the merc and a ford '39 trans? I read a comment somewhere that the Merc will have 16 teeth on the first gear and is a more desirable ratio but really i'd like some definitive information. I had a look and it had a weird serial number on the bellhousing top section, and i can't see the case number as the rear mount is still covering it. It came out of a one owner original '39 Mercury so it is infact a Merc trans for those that will doubt it.
    Appreciate any information! Here's a picture of it.. original paint too.
  2. flatjack
    flatjack
    What was the serial #? If Merc it should start with 99A.
  3. Model A Gomez
    Model A Gomez
    I thought that Ford and Mercury transmissions were the same and Lincoln Zephyr had the taller first gear. I have a 40 Mercury trans in the attic guess I better take a look at it.
    X38 likes this.
  4. Ford and Mercury are the same. Lincolns have the variant gear ratios.
    FredDobbs, LOU WELLS and lurker mick like this.
  5. Kiwi 4d
    Kiwi 4d
    @28A , from your pic we can “clearly” see they are the same as Ford transmissions.
    That aside the rear gears in a 39 merc are different to Ford in that the pinion is a solid shaft right to the transmission universal , and the gears are 3.54 .
    lurker mick likes this.
  6. The serial number wasn’t 99A but also wasn’t any Ford one I’ve seen either. It’ll have to take another look but it was just a random bunch of numbers and letters from memory.
