Difference Between a 500CFM and A 600CFM
Discussion in 'The Hokey Ass Message Board' started by 345 DeSoto, Feb 28, 2009.
  1. I was going over the Specs on the Edelbrock AFB's and noticed that, other than jet/metering rod sizes, the 1403/1404 500CFM carbs are identical to the 1405 600CFM cabs. Both have the same primary/secondary venturi diameters, identical primary/secondary throttle bores, identical pump nozzle diameters, needle/seat, and step-up springs. Any thoughts on how, except for jets/metering rods, one could flow 100CFM more than the other?...:confused:
  2. 73RR
    73RR
    ....more of that 'fuzzy math' our friends like to use...
    If the venturi and throttle bores are the same then Giovanni Battista Venturi, (1746–1822), would probably argue that they flow the same.
  3. Truckedup
    Truckedup
    From what I see the 500 cfm carb primary venturi cluster or booster is more restrictive.
    jimmy six likes this.
  4. the bores of a 500 CFM edlelbrock are smaller than a 600 CFM
  5. Relic Stew
    Relic Stew
    from Wisconsin
    Probably a different booster venturi. Provides a stronger signal to the metering well, but more restrictive to airflow.
  6. Bores of the 500CFM and 600CFM are identical...
  7. plodge55aqua
    plodge55aqua
    from Alberta
  8. i guess we are going to disagree on that...where are you coming up with the bore sizes? i don't see that info on edelbrock's website.
    i'm going by the 1404 and 1405 i have right here
  9. R Pope
    R Pope
    "100".Haha. What he said!
    Yes,the boosters are different sizes. Doesn't take much in the venturi to make 100 CFM more or less.
  10. marks914
    marks914
    Alliance Vendor
    All I can say is I think the primaries on the 500 are smaller. I swapped my 600 for a 500 and the primaries looked smaller to me, I did not measure though. I will say this, I am running a wicked cam with about 10hg/in vacuum at idle and the 500 idles and responds better even though I gave up some top end
    Mark
  11. fab32
    fab32
    Which is exactly what you'd expect from a smaller CFM carb. Way more streetable with a big cam but the top end will suffer. Now you get to decide where you want your performance, in the mid range or WOT. How much time do you spend at WOT vs cruising at part throttle?
    Frank
    Deuces likes this.
  12. Phillip H likes this.
  13. I'm going to put these 500's on a 6-71 on a 291 Hemi. I'm HOPING they'll be fine. I went with the smallest AFB style carbs I could find, since the engine cubes are small. Just wondering on the 500/600 though...
  14. 333 Half Evil
    333 Half Evil
    I have several 500 and 600 afb's and the difference in them is the primary boosters. The boosters on the 500 are smaller id and larger od therefore restricting the amount of airflow through the same size venturi. You can swap the boosters from a 500 into a 600 and..... you guessed it...your 600 is now a 500 and vice versa.
    bchctybob likes this.
  15. marks914
    marks914
    Alliance Vendor
    Yes, its a trade off, but the car is much more fun and easier drive with the 500, so thats what I have kept on it. Whats the point of screamig at 7000RPM if the car bucks and shdders getting there? I should have just run a closer to stock cam.
    Mark
    James Jenks likes this.
  16. adapter carb.jpg Found this LINK -mhttps://www.ebay.com/itm/CARTER-EDELBROCK-AFB-CARBURETOR-600-to-500-CFM-CARB-RESTRICTORS-PRIMARY-SIDE-/274478419807?hash=item3fe8304f5f%3Ag%3AK%7E8AAMXQJRhRZk%7EF&nma=true&si=4HczDouz6Kk9lHrhI4q5%252FAQOPTg%253D&orig_cvip=true&nordt=true&rt=nc&_trksid=p2047675.l2557
    AUCTION IS FOR 2 PRIMARY RESTRICTORS
    WILL TAKE 100 CFM OUT OF THE PRIMARY SIDE
    FOR WEBER MADE AFB CARBS (CARTER/EDELBROCK)
    WILL CONVERT EDELBROCK/CARTER AFB 625/600 CFM TO 500 CFM
    SOME CARBS MAY NEED THE CASTING FLANGE FILED OFF
    OF THE BOOSTERS TO FIT.
    THESE SLIDE RIGHT OVER MOST WEBER MADE AFB CARBS
    THE 1405/9605 CARBS WORK WELL WITH .086" JETS (70-47 RODS ARE STOCK)
    1406 WILL NEED .089" JETS (75-47 RODS ARE STOCK)
    YOU WILL NEED TO TUNE YOUR CARB SO IT RUNS FOR YOUR APPLICATION
    USE JB WELD TO INSTALL
  17. gimpyshotrods
    gimpyshotrods
    They will be fine.
  18. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
  19. gimpyshotrods
    gimpyshotrods
    No.
    I just worked 106 hours, and how have insomnia.
  20. 363wcpe
    363wcpe
  21. Just setting the world right, even if it's eleven, plus years ago.
    Deuces and bchctybob like this.
  22. jimmy six
    jimmy six
    409’s had 2 400’s as I remember and seemed to work just fine. Getting tough to find now and bigger buck$.
    Deuces likes this.
  23. Brand Apart
    Brand Apart
    from Roswell GA
    Hey I don't think the age matters, I used to tell my service manager all the time when the vehicle manufacturer used to come out with "new" tests "Ohm's law didn't change, why we need a new test on it"
    Should be same for CFM's haha
