Technical Difference between fenders
Discussion in 'Traditional Hot Rods' started by timkins, Jan 2, 2025.
  1. timkins
    timkins
    What is the difference between rear fenders for the 32 Sedan, Coupe and Roadster.
  2. KevKo
    KevKo
    from Motown
    Coupe and roadster should be the same. Tudor, Fordor and phaeton should be the same, but won’t interchange with coupe/roadster. Not sure about Vicky, but suspect same as roadster and coupe. Not sure about pickups, but suspect they are unique. Not sure about Woody.
  3. 34Phil
    34Phil
  4. alchemy
    alchemy
    Vicky are like sedan.
    The main difference between coupe and sedan styles is the coupe has a roll all the way around the top edge, with the vertical flange. The sedan is basically the same stamping but most of the vertical flange has been trimmed off and it uses vertical bolts to hold it to the body at that edge.
    Tow Truck Tom likes this.
