Hot Rods Difference between left and right door skins for 34 Ford Pickup
Discussion in 'The Hokey Ass Message Board' started by HardcoreZ28, May 14, 2020.
  1. HardcoreZ28
    HardcoreZ28
    What's the difference from side to side on the door skins for a 34 Ford Pickup? I see them listed as different part numbers but looking at my originals can't see an actual difference in the shape.
    Sent from my SM-G920V using The H.A.M.B. mobile app
  2. scrap metal 48
    scrap metal 48
    The hinge cutouts for one...
    irishsteve, Enola Gray and X38 like this.
  3. Enola Gray
    Enola Gray
    scrap metal 48 likes this.
  4. 56don
    56don
    Its hard to explain, but the contour is different. I found out when I tried to use one side as a patch for the other side and the contour did not match. Just make sure you use the correct one.
  5. HardcoreZ28
    HardcoreZ28
    I think I ran into the same issue as you. I got the panels years ago and finally installed them and one side the edge at the rear of the door sits further from the body a bit. I think I must have ordered 2 of the same side as well.
    As for hinge cutouts....none in these
    scrap metal 48 and 56don like this.
