Difference between pinto and Mustang II strut rods
Discussion in 'The Hokey Ass Message Board' started by Crusty Chevy, May 1, 2012.
  1. Crusty Chevy
    Crusty Chevy
    Is there a difference between pinto and mustang II strut rods? Ch***is Engineering says in their instructions to only use pinto strut rods, but all that are available are listed as pinto/mustang II not just plain pinto. And yes this in a fat fender car. Thanks in advance
  2. Markgyver
    Markgyver
    I always thought they were the same.
  3. Dave 39
    Dave 39
    Definately not the same. The bend is a different angle. Dave
  4. I don't think it will matter which you use if they are different.
    Here's why.
    You are gonna bolt the strut rod to the lower "A" arm , then with the FULL weight of the car on the suspension you will buy, make , or come up with a bracket to attach the strut rod to the frame
    If the MII is a straight rod then use the Pinto as it has a bend that will bring it toward the frame.
  5. Kenneth S
    Kenneth S
    The only Pinto strut rods that are different are the early 1971 - 73 Pinto's. In the 1974 and up Pinto's/Mustang II's use the same parts, and they are beefier parts than the early Pinto's.
  6. Dave 39
    Dave 39
    What Cape Cod Bob said is true, but if you are using a Ch***is Eng. kit you must use the strut rod designed for that kit. Their kit has a bracket that triangulates back to the main cross member. I've used two and the;re very well designed kits. Dave 39
  7. Crusty Chevy
    Crusty Chevy
    The reason for this post was that I have the CE crossmember kit and an old set of Mustang II strut rods that I got at a swap meet and the angle is close but not right with their mounting brackets. If I wedge them in they push the lower arms forward and are in a bind. I think I will order rods from CE rather than trying to bend these to fit, safety first. Thanks everyone
  8. frank dog
    frank dog
    Why not just eliminate it and convert it into a lower A arm set up.
  9. Kenneth S
    Kenneth S
    That's the way to go.
  10. Crusty Chevy
    Crusty Chevy
    There is something about the back half of the lower A-arm just hanging out there in space, in single sheer, that I do not like. Ford engineers with much more schooling in engineering than me designed it that way for a reason. The strut rod is in effect the rear arm of an A-arm and is attached directly to the frame not just hanging out there. I wish the aftermarket would make the crossmembers wider at the lower a-arm attachment and then that would be the way to go but they stick with the skinny crossmember and expect you to weld a tube to it with a single gusset. I would love to see some video footage of that gusset/tube and rear arm area during driving, I bet it is flexing all over the place.
  11. Hackerbilt
    Hackerbilt
    Pinto and MII may not be the same...at least with some versions of the MII.
    The 78 Cobra II I had years ago used a rubber bushed crossmember to hold the strut rods.
    That MIGHT make for different angles...but I really don't know AND I'm not sure if all the MIIs were configured the same.
    Might be just the V8 cars.
  12. Firecat7
    Firecat7
    no problems with heat n bend to the angle you need,tis not rocket science.just dont wedge ,jam,n bolt together. fit it under no tension.:)
