Difference in Lincoln V12 Dizzys?
Discussion in 'The Hokey Ass Message Board' started by G V Gordon, Aug 15, 2007.
  1. G V Gordon
    G V Gordon
    from Enid OK
    I have what I am sure is a Lincoln v12 distributor that was in a box of V8 stuff I was moving from the farm. I posted it in the cl***ifieds and a fellow HAMBer said the top holes were different than his. After looking at a couple of pictures on ebay, mine is different.
    This peaked my curiosity so I started looking for info on the www and came up empty. Pic included. The difference is the top holes on mine are equally spaced where on the pictures I have found the two nearest the block are closer together.
    Any help?
    GV
      26.2 KB
  2. lakes modified
    lakes modified
    Sure looks like one to me.
  3. FrankCowan
    FrankCowan
    the distributor I have measures 2 1/2" hole to hole on the two holes closest to the block and 3 3/4" to the front hole from either of the back two.
    I have two v12s don't know what year but the numbers on the blocks near where the trani mounts are
    56H A31622
    A237
    B2
    and
    56H A31622
    L127
    B2
    Any idea where I can find out the year?
    Thanks
    Frank
  4. G V Gordon
    G V Gordon
    from Enid OK
    I've been informed that what I have here is a '32 V8 distributor. thanks Rollie Customs.
    GV
  5. RilleCustoms
    RilleCustoms
    Its Rille ! lol
  6. I'm Tooratly
    I'm Tooratly
    Actually it's a 33-36 V8 distributor. 32's have the oiler in a different place.
  7. RilleCustoms
    RilleCustoms
    looks the same , no ?.....yes, btt
  8. Bruce Lancaster
    Bruce Lancaster
    Yep--'33-6 V8. LZ distributor has same mounting flange (this did not go unappreciated by early rodders...), LZ has bigger everything else, coil flange differs from any Ford, though one of the many different recipes for dual coil flatheads used an LZ coil on an adaptor on a /37-41 distributor with some Lincoln innards.
  9. G V Gordon
    G V Gordon
    from Enid OK
    They knowledge on here always amazes me.
    Thanks for the info.
    GV
  10. RilleCustoms
    RilleCustoms
    Lincoln dizzy !
  11. Elrod
    Elrod
    I recently acquired a 33-36 V8 distributor that has the adapter and LZ coil.
  12. Elrod
    Elrod
  13. alchemy
    alchemy
    That's a neat piece Elrod. Converting the Ford distributor to hold the V12 coil and rotor is much rarer than converting the V12 distributor to fire only 8 plugs. The magazine article you show is the usual way they were done. At least that's what we usually find still surviving.
