Differences in 34 and 35 torque tubes.
Discussion in 'The Hokey Ass Message Board' started by Clutch Face, May 1, 2013.
  1. Clutch Face
    Clutch Face
    What is the difference in a 34 and a 35 torque tube?
    I always see 35 torque tubes being used for lake style headers, etc.
    I have a damaged 34 tube available and would need 1 more, if these would work.
    Thanks
  2. exStreamliner
    exStreamliner
    The 35-36 drive shafts go from small diameter on each end larger center... the 33-34 is a straight tube... the driveshafts are a heavier go that after market tubes but work well
  3. Carter
    Carter
    It's not the torque tube that is used for the headers, it is the driveshaft inside the tube. As mentioned, the 33-4 driveshaft is straight tube, while the 35-6 shaft tapers from small to large and back to small again.
    Sent from my DROID device using the TJJ mobile app
  4. Marty Strode
    Marty Strode
    This is a 35-36 part.
  5. Clutch Face
    Clutch Face
    Thanks for the education, that was painless.
  6. hugh m
    hugh m
    from ct.
    Always thought the same erronious thing, been saving a 34 torque tube for years.
  7. Dale Fairfax
    Dale Fairfax
    I guess you COULD us the torque tubes instead of half a tubular drive shaft. They're bigger and not as aesthetically pleasing but I've seen a lot of track roadsters and hardtop stockers back in the '50s using the torque tubes. They sure made the old flatheads sing in a baritone.
  8. hugh m
    hugh m
    from ct.
    Gonna use mine on a 4 cylinder T, with a muffler inside.
  9. no55mad
    no55mad
    In Michigan - 50's/60's I remember them called 'bellow tubes' when used as exhaust.
