Technical Different ways to do center-steer?
Discussion in 'The Hokey Ass Message Board' started by sgtlethargic, Jun 7, 2023.
  1. ...
  2. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    So you want to be different go for an external roll cage.
    I am not drunk:eek:
  3. leon bee
    leon bee
    Wife rides on one side of you, mother-in-law on the other side?
    Bandit Billy and Tow Truck Tom like this.
  4. Ned Ludd
    Ned Ludd
    I don't share your safety concerns, but I have had a thought about better packaging for three-abreast seating, given a scratch or fairly intrusive build. Install engine back-to-front; bolt TH425 to what is now the front of the engine; run driveshaft to offset rearend. The tunnel would run between the right and middle passengers.
    It would work well in my RHD environment, the local dearth of TH425s notwithstanding, as the tunnel right next to the driver would provide a place for a console, shifter, etc. It might also work with central steering, with the tunnel to the right of the driver. Packaging might still be tricky, but it might be easier to tuck the steering gear under the pulley end of the engine than snake a column around the transmission and flywheel.
    Central steering on passenger cars isn't unprecedented, but it was something which tended to appear in the company of other kinds of weird. The Panhard Dynamic of 1938 is an example:
    How they did the steering, I have no idea.
    Edit: the wheel was offset a bit to the right, so the steering column probably just ran close alongside the engine:
    hfh likes this.
  5. '29 Gizmo
    '29 Gizmo
    from UK
    There you go......
  6. 210superair
    210superair
    from Michigan
    Sand rails and dragsters can do it because there's no motor in front of you, nor drive train under your feet. I don't see this idea panning out. No place for pedals in a normal car....
  7. Budget36
    Budget36
    With a transmission tunnel, I’d think you would have (assume an automatic) gas pedal on the right side of the tunnel, brake on the left. Seems like an awkward way to drive.
    As far as the steering, I’ve seen those “things” (technical term) that people use when the column is offset too far. I guess they are chain driven with a tensioner or gears? No clue. Don’t even know if something like that is made to cover the distance required.
  8. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
  9. goldmountain
    goldmountain
    I had a '61 Ranchero. Why would you want to straddle that transmission hump anyhow?
  10. winduptoy
    winduptoy
    You would be the only kid on the block.....
    Tow Truck Tom likes this.
  11. BamaMav
    BamaMav
    from Berry, AL
    If you’re that worried about getting T boned, put in a full race cage, or just stay at home.
    Life is full of risks, worrying about trying to cover all of them will drive you crazy.
    mustangsix and 210superair like this.
  12. mustangsix
    mustangsix
    Well, I'm not sure of the motivation, but maybe the easiest way would be to buy or build something like one of those steer-clear devices.
    You could end up like a McLaren F1?
    Ned Ludd likes this.
  13. FrozenMerc
    FrozenMerc
    Sounds like you are describing a Sprint car setup. One way or the other you will likely end up with a steering gearbox, and brake / clutch master cylinders + pedal****emblies under the dash. Shift linkage could also be fun, cable pull maybe?
  14. 34Phil
    34Phil
    you could put a u-joint behind the wheel and another at the firewall
  15. Mr48chev
    Sounds like you have a bad case of paranoia but with the screwball drivers around here I can see your point. A far better solution might be to reinforce the insides of the doors with crash bars even if they weren't much more than were required after 1968. Then build an actual cage in the car/truck. That and install some Altman or other latchs that won't pop open.
    As far as the 68 column goes, get a 68 style box to go with it. I am pretty sure that it bolts up the same as the early boxes.Rock Auto says 67/70 Mustang and Cougar boxes are the same but there are two sector shaft diameters and turning ratios.
    I can't blame you on the column.. one memory that sticks in my mind 58 years later is holding a flashlight at a headon wreck one night while the first responders pulled a guy off the steering column that he was impailed on in a 65 Mustang that he hit a VW bug head on in in the fog.
  16. 34Phil
    34Phil
    If you have a couple u joints the shaft should fold up.
  17. 210superair
    210superair
    from Michigan
    Many a man has met his fate on the road he took to avoid it.
    I agree with what's been said above if you're honestly that worried about being t boned, do a cage, or drive a modern car. I honestly doubt a center steer vintage car is going to protect you as much as you think anyway. These cars aren't designed to crumple up or protect passengers like modern cars.
