Technical Dim Those Lights !!
Discussion in 'The Hokey Ass Message Board' started by lostone, Dec 7, 2022.
  1. lostone
    lostone
    from kansas
    So how do you run your dimmer switch?
    Sitting here and looking at where to place things like brake pedal and gas pedal then got to thinking on my 31 tudor about a dimmer switch..... floor mount or switch mount..... I prefer the floor mount as it takes me back to being young but not sure yet of floor space.
  2. pprather
    pprather
    My A had it on the toe board to the left.
    GordonC, de-fenders and lostone like this.
  3. mitch 36
    mitch 36
    The dimmer in my 36 Chevy is in the original upper left toe board just like all the other cars I had prior to the newer ones that are on the stalk. On my 36 Ford, I mounted the floor mount dimmer under the dash along side the column just to clean things up.
    lostone and chryslerfan55 like this.
  4. 38Chevy454
    38Chevy454
    All my builds put it on left floorboard area. Not too high up so within easy access, but farvenough out of the way for normal driving.
    Blues4U, lostone and chryslerfan55 like this.
  5. 57 Fargo
    57 Fargo
    They are supposed to be on the floor just like the park lights are supposed to shut off when the headlights are on.
  6. lostone
    lostone
    from kansas
    I had forgotten about that! Funny how things slip away after time and then all of a sudden it seems like it was yesterday.
    57 Fargo likes this.
  7. 2935ford
    2935ford
    Yup, stomper switch on the floorboard.
    lostone likes this.
  8. rusty valley
    rusty valley
    If its an old Ford, God and Henry said it belongs on the steering wheel. end of discussion !
    lostone likes this.
  9. goldmountain
    goldmountain
    Ended up using a momentary switch from Ron Francis at the end of my turn signal stalk that engages a Volkswagen dimmer relay because I ran out of space on the floor.
    pprather and lostone like this.
  10. Bugguts
    Bugguts
    Mine are changed with the headlamp switch.
    Pull out to 1st stop and the running lights are on.
    Pull to 2nd stop and the Low beams are on.
    Pull all the way out and High beams are on.
    My 29 A doesn’t have a lot of room on floorboard for switch and my foot to access it.
    36cab, 1oldtimer, Chili Phil and 5 others like this.
  11. lostone
    lostone
    from kansas
    I guess I'm not old enough to realize they actually put one on the steering wheel !
    rusty valley likes this.
  12. lostone
    lostone
    from kansas
    How do you like it? I've seen those switches but figured it's one of those things that the switch has to be close to the driver to make it not so annoying.
    Bugguts likes this.
  13. wheeltramp brian
    wheeltramp brian
    On my 29 with three pedals I kind of ran out of room so I mounted it right underneath the dash to the left of the steering wheel so I can reach up and push it with my hand
    lostone, Driver50x and knucklenutz like this.
  14. rusty rocket
    rusty rocket
    Yeah what bugguts said. I have two cars with that switch and one I’m building will also.
    lostone likes this.
  15. fastcar1953
    fastcar1953
    Floor it ,Baby. :D:D:D
    lostone likes this.
  16. BamaMav
    BamaMav
    from Berry, AL
    On the floor, just like it should be.
    lostone likes this.
  17. rusty valley
    rusty valley
    I am really surprised that so far, no one in this thread likes the original ford switch on the steering wheel ! Ya'll running GM tilt columns or what? Early bodies are so narrow to start with, one more thing on the floor makes it even tighter. The early ford ignition switch, and wheel mounted light lever is quite desirable IMHO, but...carry on
    lostone likes this.
  18. Jack Rice
    Jack Rice
    Mine is a unique situation, I have a prosthetic right leg that's mostly just a kickstand. On my 36 pickup I mounted
    the accelerator pedal on the left side of the floor board close to where the dimmer switch would normally be.
    Using an existing hole in the dash I mounted a floor style dimmer switch on the left side of the dash. I even put
    an old Cal Custom mini barefoot cover on it.
    scotty t, lostone, Jokester and 2 others like this.
  19. '29 Gizmo
    '29 Gizmo
    from UK
    I have used a rotary switch on a modified dash panel my model A. The steering wheel switch was repurposed to operate the turnsignals and the floor space was already crowded with the standard furniture.
    lostone and vtx1800 like this.
  20. Petejoe
    Petejoe
    from Zoar, Ohio
    I installed mine on a two position switch at the dash. One pull turns them on. The next pull turns on the brights.
    I like toe board switches better.
    lostone likes this.
  21. Phil P
    Phil P
    I made a small panel to the left of the steering wheel with the starter ****on, accessorie switch, light switch(all the lights including low beam), and high beam switch.
    Now high beam is a generous term as I still have the stock model A head lights.
    Phil
    lostone and Elcohaulic like this.
  22. Automotive Stud
    Automotive Stud
    In my A's I have it on the toe board, below and centered between the clutch and brake pedals since there isn't much room to the left of the clutch.
    lostone likes this.
  23. Ned Ludd
    Ned Ludd
    I had the dimmer on the floor in the Morris Minor, and I couldn't really see any advantage to that arrangement. I tend to drive like a '60s rally driver, so I'm already stretching my two feet a bit thin a lot of the time.
    I like to have the dimming function literally at my fingertips, but at the same time, I really don't like the look of modern indicator stalks. If I get to implement this idea, using a motorbike speedometer drive to provide self-cancelling to a discreet underdash stalk, the dimming action would be by pushing the stalk inward towards the steering column.
    lostone likes this.
  24. Elcohaulic
    Elcohaulic
    I was thinking about a line lock switch on my Hurst AutoStick since it looks like a four speed allready. I'll do that or use it for a back up light switch..
    I could also pick up a Cal Custom , , finned aluminum switch box and mount it on the floor next to the shifter boot. There was a company that made a real nice looking switch plate to accommodate a small group of 2-1/4" gauges, along with lights and switches.
    I might put a pair of 50s-60s looking, interior lights on each side of the on the sides of the box.
  25. Learned this one from my old boss at the rod shop. To save space in an early hot rod just mount a GM foot switch in the kick panel to your left. Just smack it with the side of your foot and it works perfect.
    In my old Touring I mounted it behind the shifter. Since you basically sat on the floor you just smacked it with your right hand
    Elcohaulic, lostone and Bandit Billy like this.
  26. Model A Gomez
    Model A Gomez
    I'm driving a Model A and wear size 14 shoes so there's no way I could use a floor mounted switch so I used a four place light switch like Bugguts.
    lostone likes this.
  27. AccurateMike
    AccurateMike
    Elcohaulic, lostone and Chili Phil like this.
  28. Blues4U
    Blues4U
    from So Cal
    The switch is floor mounted in both the A pickup and the 47 coupe. If I had 3 pedals in the A I could see where placing the switch would get difficult, just not a lot of room available, but with just the throttle and brake pedals I have somewhere to rest my left foot, and have room for the bright switch.
    Putting it on a switch on the dash really doesn't seem practical to me, especially with a manual trans. Between steering with one hand and changing gears with the other some how you have to be able to reach up and switch off the brights to avoid blinding oncoming traffic? I guess if the roads where you drive are mostly straight and you can steer with you knees to keep it headed straight ahead for a couple of seconds while you operate the switch, that might work. Not sure I want to be on the road headed towards you at night though.
    Ned Ludd and lostone like this.
  29. Blues4U
    Blues4U
    from So Cal
    I like this idea.
    lostone and Tman like this.
  30. Jethro
    Jethro
    I did this in my coupe , channeled 4 inches and recessed firewall 3 inches I kept hitting the dimmer every time I changed gears or tried to rest my left foot.
