Technical Dingle ball honing (oh no not again )
Discussion in 'The Hokey Ass Message Board' started by dave 62 pb, Dec 23, 2022.
  1. dave 62 pb
    dave 62 pb
    I am looking to buy a dingle ball hone , I am in the UK and found a supplier over here but a bit stuck on which to purchase as they offer different grades , Silicon Carbide / Aluminium oxide /Boron carbide / Levigated alumina , then grit grades from 20 to 800
    Basically my block was bored and did little use before damaging a piston and bending a rod , it has been lying around for a few years so just want to give bores a clean and light hone to bed in new rings
    any advise welcome
    Thanks
    Dave
  2. alanp561
    alanp561
    Dave, there are several threads related to your question here on the HAMB. I just typed in "honing cylinders" in the search bar and there were your answers. Hope this helps.
    X38 and SS327 like this.
  3. bobss396
    bobss396
    You are not going to get a decent cross-hatch with a *********** hone. You just may be best off with some crocus cloth by hand using a light oil.
    chryslerfan55 and wheeldog57 like this.
  4. 2OLD2FAST
    2OLD2FAST
    from illinois
    Always worked fine for me , moly rings seat immediately .
  5. Jmountainjr
    Jmountainjr
    Not sure a ball flex hone is your best bet as you said the engine damaged a piston shortly after ***embly. Do you know why? Probably piston clearance? In any case I would want to use a fixed hone that can cut a round hole without taper and recheck all piston clearances. A flex hone will not do that.
  6. dave 62 pb
    dave 62 pb
    The engine was a marine , it had been rebuilt and run for only a short time when it ****ed water through the card and hydraulic breaking off one long skirt off a piston and putting slight twist in a rod , everything else in the engine is undamaged , got a new rod to match others and a new set of pistons and rings , I have a new 3 leg honing tool i could use just think i will get better results with ball type hone
    GlassThamesDoug and Mr48chev like this.
  7. 57 Fargo
    57 Fargo
    Damnit! I wish I had known this before the last dozen or more engines I’ve used them on…
  8. 1971BB427
    1971BB427
    from Oregon
    Ball hones work better than the old 3 bar hones, and do a better job of achieving the 45 degree crosshatch recommended by ring suppliers. Which grit is up to the ring supplier, and most state the grit on their packages. I'd never use finer than 400 grit, as it will be too smooth and not get good ring breakin.
    Run the drill at around 600 rpm's and up and down as fast as your arms can handle to get a good pattern.
    You need to soak the hone in oil prior to using it the first time as the balls actually soak up oil, and if only oiling the cylinder they'll draw up that oil. Before starting oil the cylinder liberally, and add oil as it disappears.
    Which material I can't say. I've never found a bunch of choices myself, and mine are too old to recall. Size is generally 1/8" over bore size though, so be sure to not go too big and have it cut too aggressively.
  9. evintho
    evintho
  10. gimpyshotrods
    gimpyshotrods
    Each of the abrasive materials listed has a different hardness.
    A light cross-hatch hone for cylinder walls in an Iron block, or a block with Iron liners should be done with something like Aluminum oxide.
    Abrasives that are of the carbide variety will remove more material than you likely want to remove.
    Aluminum oxide is less aggressive, and will allow you to "sneak up" on what you want, without risk of overshooting it.
    400-grit, and 30W oil is where it's at.
  11. Mr48chev
    Just hone it with your three stone hone (with the right grit for a proper cross hatch) and done.
    You are just going to freshen up the surfaces and not actually take any metal off anyhow and the stones work better to handle any imperfections.
    Here in the states a lot of us call the dingle ball hones "glaze breakers" Many of use them to knock the glaze off the cylinder walls of a block that we are just going to do a quick cast iron ring and bearing job on and expect to get another 70K miles out of it.
  12. I dingle-balled my block. Worked great. Used trans fluid for lube. Yes it makes a mess :D
    I was told to use the fewest number of strokes possible ... just enough to get an acceptable surface.
    It has been several years since I did the dingle-ball dance (the engine is still running in my daily and has 10's of thousands of miles on it) but I personally think that 50 strokes sounds like an excessive amount.
    Unfortunately I have no idea what grit my stones are :eek:o_O :D
    I used a 1/2" electric drill and, due the the drag, wasn't able to maintain a good, steady speed using the variable speed dial on the trigger so I just kept pumping the trigger to keep the unit spinning without it going to fast or causing it to stop.
  13. ClayMart
    ClayMart
    Maybe just a lingering, faulty memory, but . . .
    Going back more than several years ago I remember being advised to not use petroleum oils for honing or glaze breaking. The oil does indeed get absorbed into the stones and attacked or softened the bonding material that held the abrasives. With enough age and use this shortened the life of the stones.
    The recommendation was to use a vegetable based or cooking oil (think Wesson Oil) which still provided lubrication but did not affect the bonding material of the stones. I don't recall that it was even necessary to clean the stones for storage afterwards.
    Or am I the only one who remembers hearing of this?
    :oops:
  14. mustangsix
    mustangsix
    I don't recall ever hearing that about the oil.
    240 grit works well for me using motor oil. It's really important to clean the bores afterwards. Those things leave a lot of very fine grit behind.
    ClayMart likes this.
  15. Jmountainjr
    Jmountainjr
    I use vegetable oil for honing. The stones don't seem to load up as much. Never heard about the adhesion issue on the carrier.
    chryslerfan55 and ClayMart like this.
  16. gimpyshotrods
    gimpyshotrods
    I have my grandfathers honing equipment.
    It has only been used with motor oil, since before I was born.
  17. metlmunchr
    metlmunchr
    Silicon carbide abrasives are normally used for grinding or honing cast iron. What you use for grinding or honing a particular material is somewhat counterintuitive. Superabrasives aside, softer and more easily fractured abrasives like aluminum oxide are used on harder materials like steel or hardened iron while harder ones like silicon carbide are used on softer materials like cast iron or even aluminum
  18. gimpyshotrods
    gimpyshotrods
    I use carbide abrasives when smoothing cast Iron blocks and heads,when I want to remove a lot of material, quickly.
    When I use Aluminum oxide, the abrasives last 10% of the time.
    Same abrasive vendor.
    All of my flex hones (ball) are Aluminum oxide.
  19. ClayMart
    ClayMart
    And it wouldn't be hard to imagine that the materials used in making these stones has changed and improved over the years.
  20. gimpyshotrods
    gimpyshotrods
    My new stuff (bought last year) is also Aluminum oxide for honing cylinders.
    Truckdoctor Andy likes this.
  21. Or olive oil, or virgin olive oil, or... if you can't find a virgin.....KY Jelly will work!
  22. Your honing a different hole with that stuff , you perv :D
  23. 57 Fargo
    57 Fargo
    I use wd40 while honing.
  24. Me too Lane ,,,,,
    I know the experts say not to use it while honing .
    But,,,it’s always done a great job for me !
    I guess I’m just a renegade !
    Lol .
    Tommy
    Oh yeah,,,,,,,,Merry Christmas everyone !
    chryslerfan55, 57 Fargo and Budget36 like this.
  25. We use dingle berry , Christmas tree , ball homes at work on engines and hydraulic cylinders .
    much , much easier to get a good finish and esier to use in a drill for a novice .
    I do have a nice self Centering fixed hone I used at times when I’m feeling fancy .
    the ball hone works great . I have one on a 6’ rod for honing really long hydraulic cylinders .works very well .
    and as far as lubricant, engine oil , hydraulic oil , atf , penetrant , chain lube .
    the ball hones at work get stored in a piece of angle iron bolted to the wall ( I have a few different sizes and lengths). Stored upright and covered with a bag to keep dust and dirt off them . And basically whatever lube is in the ***embly I’m honing I use that fluid on the ball hone , never had an issue .
  26. Budget36
    Budget36
    I’d rather use a dingle berry hone on a non machined cylinder, than a rigid hone. But the engine the OP is talking about, probably doesn’t have a ring groove or taper after the rebuild.
    I think it was asked, but is the cylinder gouged , etc?
    Edit: had to fix my auto corrects.
  27. I was taught to use ATF when honing and I’ve always had good success with it.
    borntoloze, egads and VANDENPLAS like this.
  28. 57 Fargo
    57 Fargo
    Hmmm…I’d never heard anyone say it was “wrong”. Anytime something comes out of the hot tank I rinse it with hot water and spray it down with WD40 to prevent flash rust.
  29. ThisOneGoesTo11
    ThisOneGoesTo11
    from Oxford, PA
    240 grit and ATF over here, you're going to wash the bores out anyway with hot soapy water then WD40, correct? Main worry is if the bores aren't round to begin with might just make it worse. 3 x-y bore measurements each cylinder Top halfway down and bottom of stroke
    GlassThamesDoug and VANDENPLAS like this.
  30. lippy
    lippy
    from Ks
    Like the guy at the motel desk, ask's the lady to disable the **** in his room. She says, we only have regular **** you sick *******. :D
    RMR&C, chryslerfan55, Tman and 4 others like this.
