Technical Dipstick for C-4 ford auto trans.
Discussion in 'Traditional Hot Rods' started by SteveMaine, Feb 24, 2022.
  1. SteveMaine
    SteveMaine
    I'm installing a C-4 trans in my stock 48 Ford. Can I use the old trans dipstick and housing, Thanks
  2. squirrel
    Yes.
    Or...
    No.
    If it fits the transmission, and fits the car, then you can use it. If not, you can't. You're probably in a much better position to figure that out, since you can see it, and I can only imagine it. Heck, I don't even know what the old dipstick and tube came from.
    55blacktie likes this.
  3. sloppy jalopies
    sloppy jalopies
    one had the dipstick turn 90*into the pan... the other just dropped straight down...
    which one do you have ?
  4. SteveMaine
    SteveMaine
    Don't really know as I don't have the dipstick that came with C-4 trans.
  5. Corn Fed
    Corn Fed
    On the C4, you will either have a hole pointing upward in the right side of the case (body) just above the pan rail behind the bellhousing area OR a threaded hole in the right side of the pan itself that open outward.
  6. sloppy jalopies
    sloppy jalopies
    which c4 bell housing ? which c4 tranny ?
  7. mmerlinn
    mmerlinn
    There are two different styles of sticks and tubes for C4s, one fitting in the case and the other screwing into the side of the pan. Needless to say they do not interchange.
    As long as you have a MATCHING tube and stick any combination of the correct style will work.
  8. sloppy jalopies
    sloppy jalopies
    i have a new tube and dipstick... want me to slide the stick to the bottom of the tube and measure
    how far from the full line to the mounting flange ?
