Dipstick tube removal
Discussion in 'The Hokey Ass Message Board' started by 4t64rd, Nov 3, 2008.
  1. So I screwed up and didn't get the old remnant of the dipstick tube (the tube got bent and snapped off about 1/2" from the block) out of the bottom of my SBC before I stuck the pan on, so now I have to figure out a way to get the tube out of the hole... Anybody else do the same stupid thing?
    Had a few ideas, squash over one side of the piece sticking out with a needlsnose pliers, and tap a nail down the side to crush the tube, and pull it out, or get a 5/16 tap and run it down the center, then put a bolt in and pull it out...(I'm thinking this will leave stuff in the pan though)
    Any others? Or do I have to bit the bullet and pull the pan.
  2. Lucky Strike
    Lucky Strike
    I had this problem. Tried all kinds of things. Finally just tried to use an ez-out. Worked.
    It grabbed the remaining tube section, spun it around in the block. I pulled back as I twisted. Pulled it right out.
  3. d2_willys
    d2_willys
    from Kansas
    Buy an EASY OUT from auto parts store and use a tap handle and turn CCW. These dipsticks are just a mild interference fit, so the easy out should work. Make sure you bring the broken off tube with you so that you can get the right size EASY OUT.
  4. Cool, I was thinking that, but I was afraid because of the EZ-outs taper, that it would just expand the tube and make it that much harder to get out.
  5. Caddy-O
    Caddy-O
    I did the same thing. Only thing to do now is to drill that ****er out.
  6. HemiRambler
    HemiRambler
    I once used a puller with a SHCS - not as nice as using a internal bearing puller, but it worked - eventually
  7. bobss396
    bobss396
    I used to punch the tube in from the side with a screwdriver and hammer to break it free then grab it with needle nose pliers.
    Bob
  8. oilslinger53
    oilslinger53
    from covina CA
    use a dent puller, or drill it
  9. Von Rigg Fink
    Von Rigg Fink
    from Garage
    dam your fast!..
    I used a dent puller once..worked just fine.
  10. I have a dent puller... that's a great idea.
  11. oilslinger53
    oilslinger53
    from covina CA
    if the screws too small take a dowel and some glue, glue it in the hole, and screw into the wood
  12. 55 dude
    55 dude
    all good ideas! make sure you have a really bright light when you do it. sometimes after you get a bite on it some heat on the block helps.
  13. Dowel trick.... that sounds good too.
  14. jonny o
    jonny o
    See if it's all the way in there... Try a paint can pry tool or 2 back to back? Maybe need to file them down a little width-wise.
  15. redlinetoys
    redlinetoys
    from Midwest
    I have used an easy out successfully for this as well. I would try it first before you get mid evil on it!
  16. Shaggy
    Shaggy
    from Sultan, WA
    run a bolt in if you dont have an easy out on hand, worked for me
  17. I had the same problem once and just clamped a set of vice grips on it, crimping it flat and sowly twisted/wiggled it out. It don't have to move much at first. Seems like I applied a little heat to the block and used wd40 too. I know, if you brake it off at the block you're screwed but, I fgured the worst I'd have to do was pull the pan. Listen to the smarterer people above.
  18. fleetside66
    fleetside66
    I ended up drilling mine out..I wish I'd thought of the EZ-out thing. The drill pretty much lifted it out in major pieces, but I had to remove & clean the oil pan & the oil pump screen, just to be safe. I bought a new chrome one (didn't see any "plain"ones) & had to grind most of the chrome off it to make it fit. Another one of those things that should be so easy & ends up being so hard.
  19. brokenspoke
    brokenspoke
    I wouldnt
  20. PRoz
    PRoz
    Squeeze it closed with some Vice Grips and then tap upwards on top side of the Vice Grips with a hammer.
