Projects Direction change, better or worse?
Discussion in 'The Hokey Ass Message Board' started by alanp561, Nov 17, 2022.
  1. This I want to see.
    alanp561 likes this.
  2. alanp561
    alanp561
    Okay, this is what I got done today. Cut the two top halves to length, set them in place and cut the center line on them. Cut the bottom halves close to length, slipped them under the top and fit the ends and bottom edge. I'll have to add about 1" to the gap between the bottom halves. Then, I can measure and cut for the joint between the top and bottom halves. I wound up with 8 1/2 half inches additional room from front to back measured from the back of the phaeton door pillars. I think there will be more than enough room for this fat boy. 20230102_085906.jpg
    20230102_124503.jpg 29 RPU Jeep hood cut and fit.jpg 29 RPU 8 and a half new inches of space.jpg
  3. Blue One
    Blue One
    from Alberta
    I like it, I built the rear section of my body from the doors back with square tubing for inner support all the sheet metal I did from scratch.
    What you’re doing shows there’s more than one way to skin a cat. :cool::D
    SS327, High test 63 and alanp561 like this.
  4. alanp561
    alanp561
    I had sort of planned on doing it your way but, the hood was close to the right shape and only $20.
  5. I’m subscribed.
  6. Dave G in Gansevoort
    from Upstate NY
  7. Zax
    Zax
    I love the use of the Jeep hood!
    Chavezk21 and alanp561 like this.
  8. 2deuces64
    2deuces64
    Great Mind-Great Job
  9. alanp561
    alanp561
    Doesn't look like I got much done today but, it was mark, cut and fit, cut and fit, cut and fit. Made a run to town for more Clecos. Got to add more panel clamps to the joint and then tomorrow, the right side.
  10. I picked up my jeep hood yesterday.
  11. alanp561
    alanp561
    Did you check out the Dodge 1500 hoods for shape?
  12. Nope- was inspired by what you were doing, plus I have an idea for the rest of the body, and want to check the fit of the rear jeep seat in a model A for myself . Might canabalize the seat belts a and e brake stuff too.
  13. High test 63
    High test 63
    Alan,
    What is the measurement now, at the center of the car, from your back panel to the dash rail between the windshield posts?
  14. alanp561
    alanp561
    ^^^ From top center of the dash rail to the inside lip of the rear panel is 40 and a half inches.
  15. High test 63
    High test 63
    Thanks Alan,
    Probably be a couple days till i get a chance to measure my stock, mocked up
    Rpu cab for comparison.
  16. Here is what I have on one of my projects. D3FBE375-CEAC-401D-B1B3-4B485BE90F0F.jpeg
    alanp561 and Okie Pete like this.
  17. alanp561
    alanp561
    Dang, 7 inches is a lot more legroom. Some days, even a blind squirrel gets an acorn :D:cool:.
  18. alanp561
    alanp561
    Today was trying to get my old Millermatic 250X to work with .023 welding wire. Works great with .030 or .035 but, with .023, it would burn back into the tip and then bird nest at the rollers. This particular machine has a "Hot Start" feature that isn't compatible with .023, it just pushes right through the material. I had found what was supposed to be a fix for this on the Miller website, but I called their tech support before cutting anything on the circuit board that would be expensive to repair. They took the serial number and part number for the board, then emailed me a schematic marked with the correct diode to cut and the suggestion that I install a toggle switch in series with the diode so that I can switch back to the hot start for larger wire and heavier material. Super nice guys to work with. I'm still working on fine tuning the machine but, I now have most of one side fit and tacked. 29RPU tacking seams with 023 wire.jpg
  19. WTF really
    WTF really
    She's looking sweet. Keep up the good work. Hood idea was a good one.
  20. Mine is supposed to be a phaeton cowl with roadster doors and brookville back panel. Tape measure doesn’t lie. EB984258-99AD-48BB-9C53-51A3232030A0.jpeg
    Okie Pete and alanp561 like this.
  21. alanp561
    alanp561
    I know that. What was I thinking? ;)
  22. A Boner
    A Boner
    Fantastic way to make your Hot Rod a comfortable Hot Rod!
  23. alanp561
    alanp561
    Been a while since I've had time to get in the shop and my daughter Alyn had the day off, so I took advantage of her good nature. Notice the carefully color coordinated shirt. First thing we got accomplished was stopping all the leaks in the brake lines. Steering column works with an F1 steering wheel and the pedals work where they are. There's so much room in there. Think I'm going to leave it unchanneled. Opinions?
    Looks right to me :)
    Grille in right place.
    Damn, I'm good;)
    Jeep YJ hood for back panel
  24. That is what progress looks like.
  25. Dave G in Gansevoort
    from Upstate NY
    Back panel is looking good. I like the "rib" from jeep hood shape.
    Masking tape hoods are okay, but if you really want cl***, use butcher's paper: DSCN1491.JPG of course it's not fireproof. And I don't think it'll hold up to thruway speeds.
    hfh, SS327, lothiandon1940 and 4 others like this.
  26. alanp561
    alanp561
    In the first chapter of Hezekiah, verse 13, it clearly states and I quote, "God hateth a smart***".;)
  27. Dave G in Gansevoort
    from Upstate NY
    I resemble that statement! And do not deny it either...
  28. Zax
    Zax
    Coming together nicely!
  29. WTF really
    WTF really
    Looks awesome just like that.
  30. Marty Strode
    Marty Strode
    Looking good Alan, great job on the grille!
