Projects Dirt Cheap Dart
Discussion in 'The Hokey Ass Message Board' started by Sharpone, Jan 18, 2026.
  1. Sharpone
    Sharpone
    Got the heater core box painted in between my wrestling match with the lower radiator hose.
  2. Sharpone
    Sharpone
    IMG_3876.jpeg IMG_3878.jpeg My struggles with the lower radiator hose is real
    Radiator Hose. 100
    Dan 0
    The bottom pic isn’t to good but I either kink the hose or I’m off parallel about 2 inches.
    I’ll return these hoses and try plan D
    Or R for custom radiator I may end with a custom radiator about 50/50 chance the /6 radiator will not be big enough.
    Dan
    MMM1693, Thor1, wicarnut and 5 others like this.
  3. oldiron 440
    oldiron 440
    Your photo of the heater core reminds me that I need to get one for the Fairlane, something I have put off for years.:)
  4. Sharpone
    Sharpone
    Some really aren’t fun the Dart wasn’t to bad. I had a bad one on an OT 68 Torino that really ****ed.
    Dan
  5. oldiron 440
    oldiron 440
    It’s funny because I don’t like the heater hoses coming off the front of the small block Ford and I probably don’t drive the old Ford but for a few days in may or October but when there’s a chill in the air the heater sure is nice. I’ve got a Edelbrock water pump with screw in fittings so maybe I should make hard lines coming off the pump to the back of the engine then enough hose to keep things from failing. IDK it all sounds like work to me…
  6. oldiron 440
    oldiron 440
    You must be getting close to a startup.
  7. Sharpone
    Sharpone
    Still trying to make a lower radiator hose work. I think I can use a Gates flex hose with 1-1/2” and 1-3/4” ends 16 inches long.
    I want to get it running and moving maybe a short drive.
    Amazing how much time I spend looking for some items.
    Dan
  8. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Good Job Good job
    Ya know there is no shame in finding a local gl*** shop that will listen to your story,
    while asking if they can share any tips ( does / don'ts ).
    Disclaimer I would be leery of any help unless the volunteer is 'Over the hill'
    Some one has helped themselves to several items in my shop.:mad::mad::mad:
    I'm gonna guess that they aren't mature enough to respect ownership.
  9. Sharpone
    Sharpone
    Thanks for the tip.
    Oh man that’s really to bad about your shop stuff. Some people just don’t care. :( What some people don’t realize or maybe they do is that some things have more value than what they’re worth dollar wise. I have some tools from both of my grandfathers that I would be sick if someone stole them. I’m sure most of us have items that into that category.
    Dan
  10. gene-koning
    gene-koning
    It looks to me that the slant 6 radiator is your biggest problem. The bottom hose connection appears to point upward, a V8 lower radiator hose would point towards the motor, straight out and almost level with how it exits the bottom tank.
    Seeing your picture reminded me that most of the 6 cylinder radiators had the lower hose connection pointing mostly upward.
    chryslerfan55 and Sharpone like this.
  11. Sharpone
    Sharpone
    You are correct. Needs two bends in a short distance to work. I think a gates flexible hose 16 inches long with a 1-1/2” end and a 1-3/4” end will work.
    Dan
  12. gene-koning
    gene-koning
    I have joined two hoses clamped together with a short piece of exhaust pipe between them, to make a hose with a strange combination of curves. If you paint the pipe black before you install it, it will last a very long time.
  13. hotrodjack33
    hotrodjack33
    Done that several times myself.
  14. Stock Racer
    Stock Racer
    This is how I did mine. I got the connector from Summit.
    Moondog13, Thor1, Deutscher and 14 others like this.
  15. Sharpone
    Sharpone
    Thanks
    Dan
  16. gene-koning
    gene-koning
    That is a nicely illustrated explanation of creating a custom radiator hose. The connector is a nice addition, but a simple short piece of exhaust pipe works just as well, if you have a piece laying around.
    If the diameter of the hose is too large and fits too loose on the male connection, I have inserted a smaller piece of hose inside the larger diameter hose (for just over the male pipe ****** end), and clamped it together like its one thick hose. There are rubber pieces available you can buy for that specific application as well, if you don't feel comfortable with just using a smaller diameter hose.
  17. Ziggster
    Ziggster
    I can understand the struggles of looking for the correct rad hose. Been there done that. IIRC, I found a Gates catalogue on-line that was at least a starting point. During that rabbit hole I came across several vids on YT showing how to bend your own custom hose. Never watched any of them so can’t say for sure if it works, but maybe worth exploring,
  18. My late father left me his tools and box and they are priceless.Especially the tools that he customized to do certain tasks.
  19. Sharpone
    Sharpone
    Woke up to 10 - 12 inches of snow. Hey it’s Wisconsin we go from 50 to 0 in a blink. Of course when it rains it pours. My water well started cycling very quickly means I lost air pressure in the pressure tank. Checked lines for leaks nope. I need a new flapper.
    On a good note I found some heavy
    1-1/2” tubing to use on the lower radiator hose.
    Dan
    MMM1693, Thor1, porkshop and 8 others like this.
  20. Ziggster
    Ziggster
    Had a leaking flapper as well. Took me a while to figure out why my pressure was so low. It’s amazing how much a leaking flapper can affect pressure/flow. Glad to hear you found a hose.
  21. gene-koning
    gene-koning
    Dan, I'm 60 miles east of Dubuque IA and 20 miles south of Monroe WI, we only got a light trace of snow on the gr*** over night, but its been spitting snow flakes off & on and the strong winds have been blowing out of the west all day. Its OK with me if you just keep that 10" - 12" of snow up there with you. :D
    Sorry to hear about the flapper valve on your well pump, but replacing the flapper valve is probably a lot cheaper then replacing well pipe or the pump. Been there, done that, 25 years ago.
  22. Sharpone
    Sharpone
    Not sure what path the snow took but 15 miles east of the river is about 6 inches. Traveling east today and only 3 or 4 near Richland Center.
    Weird
    Dan
  23. oldiron 440
    oldiron 440
    In northern Iowa we received 3”+- last night, well I guess after 3 yesterday afternoon. I sure miss the fifty degree days earlier this week.
  24. Sharpone
    Sharpone
    MMM1693, Thor1, brad2v and 9 others like this.
  25. chryslerfan55 and Sharpone like this.
  26. Ziggster
    Ziggster
    These 90 degree elbows from Gates saved my bacon. Can’t recall what size you’re looking for but I’m sure they likely have it.
    A long shot, but Gates 20225 looks like it might sorta work again depending on ID that you need.
  27. Sharpone
    Sharpone
    The biggest issue is 1-3/4” on pump end and 1-1/2” on radiator end. I think this will work for now. Thanks all.
    Dan
  28. oldiron 440
    oldiron 440
    They, Gates I believe sells an adapter for radiator hoses. I use one on my Plymouth, I can’t remember the exact size but I go from the big block water pump housing to a small block size on the radiator. Basically what it is a rubber collar that goes over the radiator lower fitting and then you put the larger hose over it, a normal hose clamp goes on the hose and you’re good to go.
    I did this on a couple other bb swaps I did and it has always worked great. I would think that any parts store has access to hose adapters either on the shelf or by ordering. The thing I like about it is that you can use the larger hose with only the fitting on the radiator being the only restriction. Like I’ve said I’ve always had very good results with them.
    https://www.cl***icindustries.com/p...c9GFxMaQuc1unHHyCj9ewYtH-scZNybsaAoQGEALw_wcB
  29. Sharpone
    Sharpone
    Thanks @oldiron 440
    Dan
  30. wicarnut
    wicarnut
    Keeps on snowing here in St Germain, 3-4" every other day, same ****, sleet first, then very cold, now enough to get out tractor snow blower Again, In our 34 years here and our age, this is getting old, PIA. The best snowmobile conditions in 20 years they say.
