Projects Dirt Cheap Dart
Discussion in 'The Hokey Ass Message Board' started by Sharpone, Jan 18, 2026.
  1. Sharpone
    Sharpone
    That’s my luck lol
    Dan
    RodStRace, Tow Truck Tom and Algoma56 like this.
  2. chevy57dude
    chevy57dude
    Looking great, Dan.
    Sharpone and Tow Truck Tom like this.
  3. Sharpone
    Sharpone
    Thanks
    Dan
    chevy57dude likes this.
  4. Sharpone
    Sharpone
    IMG_3815.jpeg Made up a Frankenstein throttle from the donor car, the original slant six throttle utilizes rod type linkage would’ve been a nightmare to adapt imo.
    Mounted it to the firewall, everything works, carb goes WO and kick down linkage functions as it should.
    MMM1693, Thor1, Stogy and 9 others like this.
  5. oldiron 440
    oldiron 440
    I’d try a throttle cable setup from a later Abody. Get everything from the pedal to the carb stud. The /6 cable will work fine it’s what I use on my 440s the intakes tend to get a little tall.
    Sharpone likes this.
  6. Flathead Dave
    Flathead Dave
    from So. Cal.
  7. Sharpone
    Sharpone
    Yes
    1963 to 1966 same basic body style.
    Dan
    Tow Truck Tom likes this.
  8. RodStRace
    RodStRace
    Used a /6 cable in my OT dart fastback when I dropped in the tall 2x4 intake. Trying to keep this from getting bumped! ;)
    Looks like with the long top part you are going to have a ton of travel. When using a cable, try not to over extend it, they stretch enough as is. Also watch how it moves thru travel. Side rub is bad.
    A friend had 4 cables break over the years in 4 very different cars.
  9. Sharpone
    Sharpone
    I added to the bottom also. When the pedal ends travel -stops- the carb is at WOT
    I’ve read about using the later model throttles, I just haven’t found one yet.
    Thanks @oldiron 440 and @RodStRace
    Dan
  10. Could've just used a pull string.
    Budget36, Tow Truck Tom and Sharpone like this.
  11. Sharpone
    Sharpone
    Ha ha ha I’ve actually had to do that once when I broke a cable.
    Dan
    MMM1693, Tow Truck Tom and Rickybop like this.
  12. Ziggster
    Ziggster
  13. Sharpone
    Sharpone
    Ziggster likes this.
  14. Lone Star Mopar
    Lone Star Mopar
    Now how many times did you smack your head on that shifter before you decided to wrap it up... Been there before, damn near poked my eye out. :D
  15. Sharpone
    Sharpone
    Actually I was more worried about the shifter than my head lol.
    I have donated some blood to this project ha ha
    Dan
  16. ClayMart
    ClayMart
    What's this Dart fastback that you refer to? Are sure it's not a Barracuda?
    :rolleyes:
    Personally, I enjoy a bit of side rub, if you know what I mean. And I think you do. ;)
  17. gene-koning
    gene-koning
    Since the "fast back Dart" is off topic, I suspect he is referring to the "duster" style Dart from the 1970s.
    Side rub on a throttle cable (and most other auto parts) causes premature wear. Not quite the same enjoyment other side rubs may create.
    The slant 6 throttle cable is longer then a V8 throttle cable, I have long forgotten the exact difference in length between the two cables, but it seems to me the /6 was was around a 3"-4" longer. When non-stock intakes and carbs were used on the later Mopar V8s, the throttle cable was often a couple inches too short.
    Also be aware that the ends of the cable that attach to the gas pedal changed sometime in the 70s, and changed again between the 80s & the 90s. You need the cable end that matches the gas pedal you are using. There are also a few different brackets the bolt on the intake that position that end of the cable differently. The bracket on the intake can also modify the adjustment for the auto trans kick down linkage. If you can find a single donor to get the gas pedal, the intake bracket, the throttle cable, and the trans kick down linkage from, you will be ahead of the game. In our area, a pre 92 (before the beer barrow intake) Dakota V6 or V8 offered a pretty nice setup that should work in your Dart, but get everything.
    Deutscher and Sharpone like this.
  18. Sharpone
    Sharpone
    Thanks Gene, I think what I have will get me up and going hopefully I can the little odds and ends to make things better at swap meets, I’ve looked in all the local junk yards already.
    Dan
    MMM1693 likes this.
  19. Sharpone
    Sharpone
    IMG_3618.jpeg IMG_3617.jpeg IMG_3614.jpeg Used some old exercise equipment tubing 2” for exhaust pipe. Made a slip joint on p***enger side for easier installation and would also be nice for oil filter changes. Using Thrush gl*** packs and exiting behind the rear p***enger wheel. We’ll see how it sounds May end up taking to exhaust shop and running out the rear.
    Dan
    MMM1693, Thor1, Squablow and 13 others like this.
  20. oldiron 440
    oldiron 440
    I’ve got a pair of those for my Fairlane, I’m curious how they sound…
  21. Stock Racer
    Stock Racer
    Nice work on that crossmember.
  22. Sharpone
    Sharpone
    Thanks
    Dan
  23. Sharpone
    Sharpone
    I had some on OT GMC 1/2 ton with a mildly cammed SBC I loved the sound, a little loud at WOT but I liked the sound.
    Dan
  24. KenC
    KenC
    Ya know, everyone has one car they remember and regret selling. Mine was a 65 Dart 273 Hi Po, 4 spd. Black w/red interior. Fun little car.
    Also the only car of mine that I got paid to wrench on!. Remember when Mopar introduced the 50k mile powertrain warranty? Mine was one of those. Bought it in 70, before it's 5 year anniversary. It was burning oil so the dealer replaced the intake manifold gaskets. Mopar requirement because they often leaked, pulling oil from the galley. We knew that wasn't the problem, but factory requirement.
    When that didn't help it was agreed that it needed rings, but the only mechanic at the little dealership quit. I needed the car and the dealer agreed to provide the parts and let me do the work at my shop. AND, when the factory paid up he would pay me!
    I bought a new timing chain kit too. Also paid a machine shop to install PC valve stem seals while I had the heads off.
    Well since I have it apart, 65s were 235hp, 66s were 250 due to a better cam, so I opted for one of those and had a local engine rebuilder regrind my lifters. Cheaper than new.
    Sure enough, a few weeks later I got a check for my labor.
    Great little car. You're gonna love it.
    Moondog13, Thor1, Tickety Boo and 7 others like this.
  25. Sharpone
    Sharpone
    What a great story.
    I think we all have a car or three we really look back on with regret.
    Dan
  26. Yup,a couple of cars and a couple of women,lol.Dart is looking good Dan...keep 'er up!
    ffr1222k, porkshop and Sharpone like this.
  27. oldiron 440
    oldiron 440
    That’s the one thing that I did as a young man was get rid of the cars I should’ve kept and appreciated the women I didn’t because I kept the ones I should have kicked to the curb very early.
  28. Sharpone
    Sharpone
    Finally warmed up enough where I can heat the garage to a working 60 - 65 degrees without going broke.
    Sanded and 2 part epoxy primed the windshield fence area before the cold snap. Hopefully I’ll get the windshield and hood installed soon.
    Then I’ll add fluids start and back out of garage so I can clean and organize.
    Dan
  29. oldiron 440
    oldiron 440
    When you have it running I would appreciate if you would video it and post it on YouTube or facebook. I sure would like to hear what your gl*** packs sound like.
  30. Sharpone
    Sharpone
    Will do
    Dan
