Hot Rods dirt track auto
Discussion in 'The Hokey Ass Message Board' started by fullhouse296, Feb 18, 2017.
  1. fullhouse296
    fullhouse296
    from Australia
    Need info on converting auto box to direct drive.no converter or clutch .The two candidates are a 3spd glide and a 904 chrys . I believe that a tap into the hydraulic lines is how its done ,but . . . ?
  2. '52 F-3
    '52 F-3
    from Central PA
    I don't know.... but I did sleep at a holiday inn express.
    I've seen one years ago and it appeared to have a manual fluid valve the was opened and closed from the drivers seat. I ***ume it byp*** pressure until closed.....
  3. 4wd1936
    4wd1936
    from NY
    Look into the IMCA series of race cars. Most if not all use this exact transmission design with a manual control and no converter.
  4. Paul
    Paul
    Editor
    you can bump one of your earlier threads asking the same question by responding to it
  5. on our IMCA modified we used a Powerglide and just tapped into the direct clutch port (plug on side of case) to dump the fluid back into the pan. We used a "clutch" pedal because at the time we were not allowed to use direct drive. You could "slip" the clutch slightly but we were using the HD plates. It p***ed tech........LOL
  6. 54stude
    54stude
  7. Engine man
    Engine man
    from Wisconsin
    There are different ways to set it up. Some used the Powerglide with the 2 speeds and a deeper low gear to start it moving. Some used a closed ratio that would shift at a set rpm on longer tracks. Some removed the low gear components and used it as a direct drive box. The main reason to use it in dirt track racing was to reduce the rotating weight so the drive train can speed up and slow down faster. A good transmission shop should know how.
    We used a Ram Coupler with an automatic flex plate. You have to push the pedal to the floor to start out then release it to lock it. Some drivers couldn't manage it.
