Technical Disc brake dust problem
Discussion in 'The Hokey Ass Message Board' started by Trikerider, Dec 2, 2020.
  1. Trikerider
    Trikerider
    from Madera,Ca
    I am running disc brakes on my 1954 chevy panel its all 1970's GM am running semi metallic pads... I have tried 3 different brands of pads over the yrs and also some covers that go on the back of the wheel with n good results still a nasty amount of dust. My wheels are powder coated and some of it has embedded itself in the coating probably from getting the brakes hot while pulling my shasta travel trailer... Anyone out there had this problem and if so what did you use to get rid of the problem...
  2. greybeard360
    greybeard360
  3. indyjps
    indyjps
    Yep its worth it to swap pads vs ruining your wheel finish, constantly washing or buying the wheel cleaner.
    Trikerider likes this.
  4. kabinenroller
    kabinenroller
    I use the “mid grade” pads from NAPA on my daily drivers, no more dust like the OEM pads.
  5. gimpyshotrods
    gimpyshotrods
  6. Elcohaulic
    Elcohaulic
  7. jimmy six
    jimmy six
    I use to buy the cheapest Pep Boys non-metallic softest pads and never had any dust or metal from the rotors which is part of the problem. good luck
  8. bill gruendeman
    bill gruendeman
    Ceramic pads are clean but hard on rotors, I was told by a brake vender only put ceramic pads on a car that come oem with them. With the amount of miles most hot rod go in a year shouldn’t be a problem.
  9. bigdog
    bigdog
    Actually ceramic pads will wear rotors less than semi metallic. Some of that black dust on your wheels is brake rotor material. Semi metallic do transfer heat better than ceramic so are better if you use your brakes hard and put a lot of heat into them. Towing, for example.
    gimpyshotrods likes this.
  10. stillrunners
    stillrunners
    from dallas
    They do make those shields that block the dust from getting to the wheels.......
  11. Trikerider
    Trikerider
    from Madera,Ca
    that was 60.00 of wasted $$ they did nothing at all
