Could anyone ID these disc brakes for me? The casting number on the driver's side is: 5232 and the p***enger side is almost unreadable. It appears to be: 5262. I would like to replace the calipers and rotors. It also has a Ford script. Thanks
You realize they are on the wrong sides don't you? The bleeder should be at the top. May be why the hoses are kinked also.
The rotor looks pretty small, so as said above Pinto or Mustang II. If you just want to replace, Speedway has them.
