Disc brake without a power booster
Discussion in 'The Hokey Ass Message Board' started by concreteman, Dec 2, 2012.
  1. concreteman
    concreteman
    Looking for ideas – I want to put a Muncie in my 34 – was going to use the Pete and Jake bracket for a hyd clutch and brake set-up – problem I may have is (power booster)the car has Mustang 2 with disc in front and drum in back – Question is has any one run a disc brake set-up with no power booster (this would be for front only)-
  2. mastergun1980
    mastergun1980
    from Alva OK
    I have ran mustang 2 front discs ( stock diameter) with stock 68 mustang drums on back . No booster. 68 mustang master cylinder. 27 t. No problems whatsoever
  3. Ole don
    Ole don
    You just have to push a little harder and keep little girls out from behind the wheel.
  4. GregCon
    GregCon
    from Houston
    Sure, all the time. No even hard to push the pedal.
  5. Belchfire8
    Belchfire8
    Got Granada rotors on a Must II frontend with no booster and it's fine, they will lock up if you need to. Also have a non power setup on a '41 ford truck and that one will lock the fronts easily.
  6. themoose
    themoose
    Early Corvettes had 4 wheel disks without power.
  7. dblgun
    dblgun
    Match the master cylinder bore to your application. You can adjust pedal pressure by increasing or decreasing bore diameter. Master cylinders for stock manual applications tend to have a deeper pedal rod hole also.
    indyjps likes this.
  8. guido`s 40
    guido`s 40
    from nebraska
    I am running disc all the way around with no booster it breaks great just a little firmer peddle then with a booster
  9. Edsel58a
    Edsel58a
    My 72 Montego GT stops fine with manual disk brakes... and it is a heavy car
  10. tommy
    tommy
    Sure this was built 30 years ago using everything from a non-power disc brake equipped 71 Camaro. I rebuilt the calipers. The M/cyl is a stock replacement for the 71 Camaro. AFAIK it's sill running the streets. I used the P&J pedal kit back then. It worked just fine. I used the brake distribution block and everything from the Camaro
  11. 32-3 WINDOW
    32-3 WINDOW
    from utah
    i have a el camino with non power disk front and drum back , and my 34 has 4 wheel disk non power , you will just have to devolope your leg mustlea little more , they work great , just a firmer pedal
  12. oj
    oj
    Most every racecar has manual brakes. A properly designed manual brake system will take 60lbs of leg pressure for an aggressive stop with 1200psi at the brake drum or caliper.
    So, yes a disc/drum combo without power assist will stop just as quick as power assist, give a brake company call with your specs before buying the MC and they will sell you the right size.
  13. concreteman
    concreteman
    You gota love the Hamb - you guys are great - ask a question and get the answer <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
    Thanks all - made my day - I will keep going with my PJ bracket idea which has the clutch and brake peddle<o:p></o:p>
  14. tommy
    tommy
    just remember to use a M/cyl that was designed for non-power brakes.
  15. concreteman
    concreteman
    Thanks - any ideas on who has them
  16. belair
    belair
    And if the M/C is under the floor you need residual pressure valves. (no big deal, but you have to run them)
  17. concreteman
    concreteman
    Thanks for the tip it will be under the floor
  18. 296 V8
    296 V8
    from Nor~Cal
    Its all about leverage &#8230;. If its to hard to push? Increase the leverage.
  19. V8 Bob
    V8 Bob
    Why?
  20. 4 pedals
    4 pedals
    from Nor Cal
    When I did the deisk conversion on my 64 I found that a 68 Camaro used the same bolt pattern on the master cylinder which was used for disk both power and non power. I've driven it that way for about 15 years now, and recently noticed that I don't have the stopping power of all the new compact cars with 4 wheel disks. After researching it some I found that I went from a 1" bore on the master to a 1.125, which made me work harder, not easier. I'll be swapping it out for a 7/8 bore master soon and expxecting a big improvement.
    Devin
  21. kiwicowboy
    kiwicowboy
    from linwood nc
    we have been running disk brakes front and rear with no boster for years,just make sure you have the rite combo.
  22. 53sled
    53sled
    from KCMO
    Um, so it works. Seriously, every day there is another thread about brakes made of non-matching parts, randomly picked from a catalog and guess what? they don't work.
  23. CutawayAl
    CutawayAl
    from MI
    Drivers in the U.S. have come to believe that every car needs power steering and power brakes. As has been pointed out, in the past some heavy cars were available with manual discs. Although there are some variables, with proper design and planning light cars typically don't really need power brakes.
  24. dirt t
    dirt t
    2lb for disc and 10 lb drum.
  25. Its all in the pedal ratio !
    Some applications DO have a different part # master cylinder for manual or power brakes some DO NOT.
    85 range of Chevy truck doesn't have any different master or calipers for power vs manual.
    What is different is the pedal ratio and on this particular truck, the brake pedal is much higher off the floor with manual brakes because the travel distance needs to be much more.
    There are different steering boxes for manual vs power. The internal gearing is different and its more turns of the wheel to go from lock to lock .
    Now I suppose I could re engineer the system by altering the master bore size and the caliper bore size and lower the pedal but I ain't.
  26. CutawayAl
    CutawayAl
    from MI
    I will be guided by what you is or ain't going to do.:D
    For safety reasons the pedal should have enough travel to at least nearly bottom the master cylinder. That needs to be taken into consideration when establishing pedal ratio and pedal height.
  27. need louvers ?
    need louvers ?
    To make things easy, A Manual disc/drum '68 Mustang master cylinder will do the deal for you quite nicely. This has a 15/16" bore and nicely balances pressure with volume for most hot rod brake needs. It will have the residual built into the rear brake chamber, so you will probably have to do a seperate 2lb residual for the front circut. By the way, one of the many reasons for using a manual master is that MOST manual cylinders have a deeper input for the brake pushrod. A very nice thing in an under floor type set up.
  28. Ebbsspeed
    Ebbsspeed
    "Randomly picked" is the key phrase here. There are plenty of resources available to figure out what size master cylinder will be required based on what calipers and drum cylinders are used. Sure it's easy to just use every component from a factory engineered system, but sometimes that just isn't possible.
    A combo consisting of components where your master cylinder bore is too small (not enough fluid volume to effectively apply the brakes) is about the only scenario where a change in pedal ratio cannot cure the problem.
  29. 53 COE
    53 COE
    from PNW
    15/16" came with the disc brake conversion kit for my Dart project. Easy to push but spongy pedal. The company swears up and down that's the right size manual MS disc/drum. I had them send me the 1-1/32" bore they have for power brakes. Have not tried it yet but hopefully it firms up the brakes without too much pedal pressre.
  30. need louvers ?
    need louvers ?
    It could, but I honestly would have gone with a 1" before a 1 1/32". As the diameter increases, the volume rises but the pressure falls, as the bore gets smaller, the opposite is true. My experience with this stuff tells me to start with 15/16" in MOST cases.
    I do have to note though that I have had one hell of a time getting systems blead lately for some reason, leaving pedals somewhat spongy feeling. Not sure why, but in my little Falcon after three goes, it's still just a bit softer than I would like. Each time I go through it again it improves though.
