Technical Disc Brakes Model A?
Discussion in 'Traditional Hot Rods' started by ‘28 RPU, Dec 30, 2025.
  1. ‘28 RPU
    ‘28 RPU
    Has anybody figured out a way to install disc brakes on a stock Model A banjo axle without adding any width?
    Or, a way to install Bendix type drum brakes on a banjo without adding width?
    I bout a full set of the Lincoln 12” brakes but the add 2.5” to the total width and I don’t have any room to spare.
  2. 1946caddy
    1946caddy
    from washington
    I had a quick-change rear end build for my Model A, which has closed drive shaft with a t-5 trans.
    1940 Ford bells and narrowed to stock width with Lincoln brakes, 9" axles and a spring on top of axle like stock. Only reason I went this way is to run Kelsey Hays wires.
    Took 8 months and almost $8,000 in total.
  3. ‘28 RPU
    ‘28 RPU
    $8k might be a bit much for me LoL.
    rpm56 likes this.
  4. rusty valley
    rusty valley
    Are you going to enter it in road race compe***ion ?
  5. ‘28 RPU
    ‘28 RPU
    Yep Rusty, that’s exactly what I’m going to do.
  6. Grumpy ole A
    Grumpy ole A
    Do already have disc brakes on the front?
  7. 29Sleeper
    29Sleeper
    from SoCal
    Narrowing the axles would be the only way. A cheap way out would be steel wheels with the right offset.
    https://www.speedwaymotors.com/1937...e-Kit-5-on-4-1-2-Metric-w-Spindle,468165.html
    If you are running a 48-inch axle, your overall width once installed will be 56-1/4 inches.
  8. 19Eddy30
    19Eddy30
    from VA
    Not as a purchased kit ,
    All custom @ mix match of parts .
    Can be done , adding 1/8 - 1/4 each side to stock A rear ... Maybe "0"
    Just takes I vision with paper ,drawings,
    Thinking .... Oh Tool's !
    Hot Rodding & Independent private ter racer thinking.
