Disc brakes on 35 ford
Discussion in 'The Hokey Ass Message Board' started by argand46, Mar 10, 2011.
  1. argand46
    argand46
    Can anyone suggest parts or kit to install disc brakes on a 35 ford that currently has drums (I'm ***uming 39 hydraulic) while keeping the wire wheels.
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    A properly adjusted early Ford hydraulic drum set-up, or the early F-100 Bendix conversion, with good drums(not turned over spec) is a very adequate setup when driving defensively.
    I've never heard of a conversion to discs which allows use of early Ford 5 on 5.5" wheels, disc or wire. Be intersting to see what pops up.
  3. 31Apickup
    31Apickup
    There are kits available that have the 5.5" bolt pattern (ECI is one), I don't know if the wire wheels will work with it. There are no disc brake conversions that I know of for 1936 and earlier spindles. The Ford kits are based upon 1937-1941 (round back) & 1942-1948 (square back spindles).
  4. Petejoe
    Petejoe
    from Zoar, Ohio
    I would not even think about changing over to discs since it already has a setup that is sufficient. Unless of course your going to street rod it. yuk
  5. argand46
    argand46
    No street rod deal here. Has 37 engine will have wire wheels & open drive w/ 5 spd. Gotta have wires & gotta stop. Live in NJ w/ more *****s per sq inch than anywhere else. need to be able to stop quickly is all. Constantly being cutoff.
